How to install PHP 5.2 and 5.3 together
e-mike
I've searched the forum and found info about installing PHP 5.2 and 5.3 together. What I miss is a simple guide how to establish this.
What I'm looking for is a simple guide how to install PHP 5.2 and PHP 5.3 together where PHP 5.2 is default and PHP 5.3 can be enabled through the following line:
# .htaccess
AddHandler application/x-httpd-php53 .php
  • PHP 5.2 (default)
  • PHP 5.3 (htaccess)
(Thus not with "x-httpd-php6" to fool DA that it's PHP 6 but it is PHP 5.3)
Has anyone the knowledge to establish this and make a simple guide? Martynas (smtalk) maybe?
Yes, it is possible to do that. Use the same guide and execute the following afterwards:
perl -pi -e 's/x-httpd-php6/x-httpd-php53/' /usr/local/suphp/etc/suphp.conf
perl -pi -e 's/x-httpd-php6/x-httpd-php53/' /etc/httpd/conf/extra/httpd-suphp.conf
That's it! Good luck :)
So we should do the following commands to achieve this, is this correct?
./build set custombuild 1.2
mkdir -p custom/suphp
cp -pf configure/suphp/configure.php5 custom/suphp/configure.php6
perl -pi -e 's/php53/phprep/' versions.txt
perl -pi -e 's/php6/php53/' versions.txt
perl -pi -e 's/phprep/php6/' versions.txt
./build set php5_ver 5.2
./build set php6_cgi yes
./build set php5_cgi no
./build set php5_cli yes
#set php6-cgi (or cli) to yes in the options.conf
./build php n
mv -f /usr/local/php6 /usr/local/php6_old
ln -s /usr/local/php5 /usr/local/php6
If so, does this only work with suPHP and thus not with php-cli?
Correct. If you'd like to have PHP 5.3 as mod_php (CLI) and PHP 5.2 as CGI (with suPHP), then it's very easy to do that too, you'd just need to modify a few steps.
smtalk, can you tell us what to do when updating DA?
Suppose you have 25+ servers and when you update DA, the change for PHP 5.3 next to 5.2 is undone with every update of DA. Is there a way to keep the extra config during update of DA automatically? You don't want to update every server by hand only for the second PHP support.
So basically my question is how to update DA with PHP 5.2 AND 5.3 automatically?
Execute the following:
./build update_versions
If you'd like to update everything and have PHP 5.2+5.3 left.
i try to install
php4 cgi yes
php5 cgi yes
php6 cgi yes ( instructions for have php5.3 )
but its remove php4 cgi
normal ?
i need 3 php cgi
i did that and when i swith for php5.3 i get internal error and i cant see my page
when i check the phpinfo in the base_dir is emty
can u help my with that
thenks
Actually im facing a problem.
version.txt is edited as described, but when i run build php n the script will donwload php 6... and version.txt go back to original...
Any workaround?
Regards
Same here, custombuild downloads php6 and installs it. Followed your instructions, except using "php6" as cli and 5.2 as cgi.
SeLLeRoNe have u resolved this?
Nope i didnt, but ive gave customers a month of time for upgrade their websites and now ive moved to php 5.3
There should be something "different" in build script that prevent this work-around to work correctly.
Regards
I think i found my issue.
smtalk's guide was for 5.3 being as cgi and 5.2 as cli. As my case was the other way around, this line was the issue:
had to do
cp -pf configure/ap2/configure.php5 custom/ap2/configure.php6
Seems to download 5.3 now, but havent yet finished the configuration so cant confirm it works.
well my problem was in build file not in configuration... he was only downloading version 6 and never 5.2 with 5.3, so maybe you had a different issue i suppose...
Regards
I need to find some time to rewrite CustomBuild to allow using few versions of PHP 5.x on the same server. SeLLeRoNe, make sure autover=no is set in the options.conf file.
Well i dont need it anymore now, but thanks :)
yes it was on yes... should be nice to get this
./build set autover no
in installation instructions.
Regards and thanks
