Why does block_ip.sh work but brute_force_notice_ip.sh does not?
donkeyKICK
I wanted to have the new feature of brute force detection trigger a block in the csf.deny file.
I went to a shell and found that csf -d worked exactly as I wanted. It put it in the file block_ip.sh and when I click the button under admin panel--> brute force monitor it behaved exactly as desired:
#!/bin/sh
csf -d $ip Added by DA BruteForce monitor
exit $?;
However, in the script brute_force_notice_ip.sh, the exact same code does not work. After looking at the thread here: http://www.directadmin.com/forum/showthread.php?41163-How-do-I-stop-a-brute-force-attack?s= I decided to try:
#!/bin/sh
/etc/csf/csf.pl -d $value Added by DA BruteForce monitor automatic
exit 0;
I don't understand why I can call the dameon in the first case, but not in the second.
I cant tell you why doesnt work, actually i didnt understand, but, i can tell you how i do.
In brute_force_notice_ip.sh put
#!/bin/sh
SCRIPT=/usr/local/directadmin/scripts/custom/block_ip.sh
ip=$value $SCRIPT
exit $?;
This work for me :)
Regards
#!/bin/sh
ip=$value $SCRIPT
exit $?;
This work for me :)
Regards
That only works if block_ip.sh has
/etc/csf/csf.pl -d $ip
in it.
I was asking why
works in both block_ip.sh and brute_force_notice_ip.sh
but
csf -d
only works in block_ip.sh and NOT in brute_force_notice_ip.sh. It should work in both or neither.... odd
The code you cited just has the brute_force_notice_ip.sh call the block_ip.sh, except that doesn't work if csf -d is in block_ip.sh
The full path works for both, but I don't need the full path for blocked_ips.sh. I just don't know why one cares and other doesn't. The full path works, so anyboy else runnng in to this should just use the full path.
Still a bit odd though.
Thank you everybody!
Probably it's an issue of ENV, probably it's an issue of yours, and nobody else would face it. So more investigation is needed.
And I really do not see anything bad in using full paths to a file.
