Suurbier
- Apr 23, 2007
I can't remove this annoying error when I try to update trough yum. I already searched on Google but i could not found a solution, I also tried this from the DA help page.
But it did not work..
This is the following error when i use yum update
wget -O /usr/lib/libmysqlclient.so.15 http://files.directadmin.com/services/es_5.0/libmysqlclient.so.15
chmod 755 /usr/lib/libmysqlclient.so.15
ldconfig
#yum update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: centos.mirror.triple-it.nl
* epel: mirror.nl.leaseweb.net
* extras: centos.mirror.triple-it.nl
* updates: centos.mirror.triple-it.nl
Excluding Packages in global exclude list
Finished
Setting up Update Process
Resolving Dependencies
--> Running transaction check
---> Package mytop.noarch 0:1.7-4.b737f60.el5 set to be updated
--> Processing Dependency: perl(DBD::mysql) >= 1 for package: mytop
---> Package perl-DBD-MySQL.i386 0:3.0007-2.el5 set to be updated
--> Processing Dependency: libmysqlclient.so.15 for package: perl-DBD-MySQL
--> Processing Dependency: libmysqlclient.so.15(libmysqlclient_15) for package: perl-DBD-MySQL
--> Finished Dependency Resolution
perl-DBD-MySQL-3.0007-2.el5.i386 from base has depsolving problems
--> Missing Dependency: libmysqlclient.so.15 is needed by package perl-DBD-MySQL-3.0007-2.el5.i386 (base)
--> Missing Dependency: libmysqlclient.so.15(libmysqlclient_15) is needed by package perl-DBD-MySQL-3.0007-2.el5.i386 (base)
Error: Missing Dependency: libmysqlclient.so.15 is needed by package perl-DBD-MySQL-3.0007-2.el5.i386 (base)
Error: Missing Dependency: libmysqlclient.so.15(libmysqlclient_15) is needed by package perl-DBD-MySQL-3.0007-2.el5.i386 (base)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
#yum list installed MySQL*
Finished
Installed Packages
MySQL-client.i386 5.1.60-1.glibc23 installed
MySQL-devel.i386 5.1.60-1.glibc23 installed
MySQL-server.i386 5.1.60-1.glibc23 installed
MySQL-shared.i386 5.1.60-1.glibc23 installed
