Complete Usage Statistics, DHCP,MAC
ben29
Israel
1}in Complete Usage Statistics i's show :
Usage Stats for eth0,
i think if it give all devices, it's could be very usefull
like example, my ethernet device is : eth0:10
it's just device to Da license, but the real connection is eth0,
2} when add new ip, it's using the same MAC addrees like eth0, it's have to be diffrent
{bug ? }
eth0 mac = eth0:1 mac
3} when add new ip, it's will be add by DHCP
3. if you want to add ip, you can do it by using dhcp. { not static }
Is it a question or a statement. I don't see a question marks, that's why I'm asking. Anyway I don't think that it is a good idea to use DHCP on LAMP servers.
You can, but you'd need to configure the dhcp server to always serve the same IP@ based on the NIC hardware address (only available on a LAN); it probably isn't worth the effort on any system where you have access to create a static IP#.
