Problem in creating a backup Admin Control Panel / DirectAdmin
abolfazl201358
Hello
After installing DirectAdmin control panel, though it is not the username admin and your username by the way we seem to Bmab backup making the system completely fails and is not able to get backup
Whether anyone else encountered this problem in Korea that will help Btvandmara
Note that no error is also Nsbt crushed the backup fails and the Aral backup I do not
Excuse the language is not good
I hardly understand your issue. Will you please post a screenshot or a full text of all errors, that you've got there.
Note, you might need to set up a backup task with "now" in Directadmin and run
/usr/local/directadmin/dataskq d800
in shell immediately to see details.
Hello
This profile was seen after the command
But the problem did not work i get more information
Excuse my language, I do not know if I'm wrong, excuse my writing
Thank you in advance
[root@server ~]# /usr/local/directadmin/dataskq d800
Debug mode. Level 800
root priv set: uid:0 gid:0 euid:0 egid:0
pidfile written
staring queue
*** IP 193.206.xxx.xxx has 191 failed login attempts. Limit=60 data='sshd4=9&sshd5=182'
*** User root has 212 failed login attempts. Limit=60 data='sshd5=212'
done queue
[root@server ~]#
You've executed
too late, do it again:
set task -> run command in shell
Maybe it would be better for you to use Google translate, as I don't understand you. I hope, anybody else here can do.
Hello
Thank you
My problem is that the backup does not look
I did run the commands you've used this method
Backup, but not the admin
Maybe I can help you use Google to translate it from
OK, I see, you've got some issues with backups. Please, write in your language, and I'll try to understand you.
Hello
It might help my Persian
My first issue of the Persian writing to you to help me
سلام
مشکل من ان است که از یوزرها روی سرور نمیتوانم از طریق ادمین بکاپ بگیرم
ولی با دستوری که شما در چند پست بالاتر دادید میتوانم عمل بکاپ گیری را انجام دهم
به طور دقیق زمانی که از این بخش
https://xxx.xxx.xxx.xxx:2222/CMD_ADMIN_BACKUP
اقدام به بکاپ گیری میکنم عمال بکاپ گری انجام نمشود چندین بار هم سرور را بلود کردم بازهم مشکل برطرف نشد
ممنون از شما
Sorry, I still can't understand what exactly is wrong. Maybe somebody else could help you.
That is what I've got from Google translate:
Hello
My problem is that the server Users can look through my backups
I command you in a few posts above you can do the backup
Exactly when this section.
Gary, I do backup agents to backup server Blvd Nmshvd several times, I still could not solve the problem
Thank you
How do your users see your backups? With SSH access? In Directadmin? Or elsewhere?
Hello
Our users have access to ssh
We're forced to make difficult Psh come to our own backups of all users.
So I set off for my trouble
The problem is that I do not say it right
Thank you zEitEr
You should never give users ssh access unless they have a specific reason for it.
