daga Verified User Joined Apr 7, 2005 Messages 8 Location UA Jan 20, 2012 #1 Hi, Installed DA by default, after, don`t send mail from DA in ticket system, and sending passwords. pop/imap webmail working. fix directadmin.conf ?
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,419 Location A Coruña, Spain Jan 20, 2012 #2 check exim and directadmin error logs.
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,250 Location www.poralix.com Jan 20, 2012 #3 daga said: after, don`t send mail from DA in ticket system, and sending passwords. Click to expand... Read /var/log/exim/mainlog as Andrea suggested you, and ask your DC. The DC might be blocking outgoing connections to remote SMTP:25.
H hostslim New member Joined Jan 27, 2012 Messages 2 Jan 27, 2012 #4 Problem fix We've had the same problem. Did you reset the permissions? Check: ls -la /usr/sbin/exim and /var/log/exim/mainlog /var/log/exim/paniclog Most common issue is a previous install of exim breaking things: chown root:root /usr/sbin/exim chmod 4755 /usr/sbin/exim chown -R mail:mail /var/spool/exim
