proftpd.conf
creaty
Hello
Having deleted my proftpd.conf file I need to have a copy!
Can you copy your proftpd.conf below?
thank you
/usr/local/directadmin/scripts/proftpd.sh
or
./build clean
./build set proftpd yes
./build proftpd d
I believe I'm correct in writing that neither copying someone else's file nor reinstalling proftpd will restore the data on which users are allowed shell access. You may be able to do that by resetting them from DirectAdmin (untested by me), but you may need to install them manually from a root shell.
@scsi,
or
./build clean
./build proftpd d
Did you manage to restore the config with suggested by you methods? I've scanned both files, and hardly could find information on where from does the config gets created.
More to say, with /usr/local/directadmin/scripts/proftpd.sh we get ProFTPD installed from rpm without proftpd.conf (?):
rpm2cpio proftpd-1.3.3c-1.i386.rpm  | cpio -idmv
./etc/logrotate.d/proftpd
./etc/pam.d/ftp
./home/ftp
./usr/bin/ftpcount
./usr/bin/ftpdctl
./usr/bin/ftptop
./usr/bin/ftpwho
./usr/bin/prxs
./usr/lib/pkgconfig/proftpd.pc
./usr/sbin/ftpscrub
./usr/sbin/ftpshut
./usr/sbin/in.proftpd
./usr/sbin/proftpd
./usr/share/doc/COPYING
./usr/share/doc/CREDITS
./usr/share/doc/ChangeLog
./usr/share/doc/NEWS
./usr/share/doc/proftpd-1.3.3c
./usr/share/doc/proftpd-1.3.3c/COPYING
./usr/share/doc/proftpd-1.3.3c/CREDITS
./usr/share/doc/proftpd-1.3.3c/ChangeLog
./usr/share/doc/proftpd-1.3.3c/Configuration.html
./usr/share/doc/proftpd-1.3.3c/Configuration.pdf
./usr/share/doc/proftpd-1.3.3c/Configuration.sgml
./usr/share/doc/proftpd-1.3.3c/NEWS
./usr/share/doc/proftpd-1.3.3c/README
./usr/share/doc/proftpd-1.3.3c/README.AIX
./usr/share/doc/proftpd-1.3.3c/README.DSO
./usr/share/doc/proftpd-1.3.3c/README.FreeBSD
./usr/share/doc/proftpd-1.3.3c/README.IPv6
./usr/share/doc/proftpd-1.3.3c/README.LDAP
./usr/share/doc/proftpd-1.3.3c/README.PAM
./usr/share/doc/proftpd-1.3.3c/README.Solaris2.5x
./usr/share/doc/proftpd-1.3.3c/README.Unixware
./usr/share/doc/proftpd-1.3.3c/README.capabilities
./usr/share/doc/proftpd-1.3.3c/README.classes
./usr/share/doc/proftpd-1.3.3c/README.controls
./usr/share/doc/proftpd-1.3.3c/README.cygwin
./usr/share/doc/proftpd-1.3.3c/README.facl
./usr/share/doc/proftpd-1.3.3c/README.modules
./usr/share/doc/proftpd-1.3.3c/README.ports
./usr/share/doc/proftpd-1.3.3c/README.ratio
./usr/share/doc/proftpd-1.3.3c/contrib
./usr/share/doc/proftpd-1.3.3c/contrib/ftpasswd.html
./usr/share/doc/proftpd-1.3.3c/contrib/ftpmail.html
./usr/share/doc/proftpd-1.3.3c/contrib/ftpquota.html
./usr/share/doc/proftpd-1.3.3c/contrib/index.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_ban.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_ctrls_admin.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_dynmasq.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_exec.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_ifsession.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_ldap.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_load.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_quotatab.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_quotatab_file.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_quotatab_ldap.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_quotatab_radius.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_quotatab_sql.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_radius.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_rewrite.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sftp.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sftp_pam.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sftp_sql.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_shaper.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_site_misc.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sql.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sql_odbc.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sql_passwd.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_sql_sqlite.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_tls.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_tls_shmcache.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_unique_id.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_wrap.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_wrap2.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_wrap2_file.html
./usr/share/doc/proftpd-1.3.3c/contrib/mod_wrap2_sql.html
./usr/share/doc/proftpd-1.3.3c/faq.html
./usr/share/doc/proftpd-1.3.3c/howto
./usr/share/doc/proftpd-1.3.3c/howto/ASCII.html
./usr/share/doc/proftpd-1.3.3c/howto/AuthFiles.html
./usr/share/doc/proftpd-1.3.3c/howto/Authentication.html
./usr/share/doc/proftpd-1.3.3c/howto/BCP.html
./usr/share/doc/proftpd-1.3.3c/howto/Chroot.html
./usr/share/doc/proftpd-1.3.3c/howto/Classes.html
./usr/share/doc/proftpd-1.3.3c/howto/Compiling.html
./usr/share/doc/proftpd-1.3.3c/howto/ConfigFile.html
./usr/share/doc/proftpd-1.3.3c/howto/ConfigurationTricks.html
./usr/share/doc/proftpd-1.3.3c/howto/Controls.html
./usr/share/doc/proftpd-1.3.3c/howto/CreateHome.html
./usr/share/doc/proftpd-1.3.3c/howto/DNS.html
./usr/share/doc/proftpd-1.3.3c/howto/DSO.html
./usr/share/doc/proftpd-1.3.3c/howto/Debugging.html
./usr/share/doc/proftpd-1.3.3c/howto/Directory.html
./usr/share/doc/proftpd-1.3.3c/howto/DisplayFiles.html
./usr/share/doc/proftpd-1.3.3c/howto/FTP.html
./usr/share/doc/proftpd-1.3.3c/howto/FXP.html
./usr/share/doc/proftpd-1.3.3c/howto/Filters.html
./usr/share/doc/proftpd-1.3.3c/howto/Globbing.html
./usr/share/doc/proftpd-1.3.3c/howto/Limit.html
./usr/share/doc/proftpd-1.3.3c/howto/ListOptions.html
./usr/share/doc/proftpd-1.3.3c/howto/Logging.html
./usr/share/doc/proftpd-1.3.3c/howto/NAT.html
./usr/share/doc/proftpd-1.3.3c/howto/Nonroot.html
./usr/share/doc/proftpd-1.3.3c/howto/Quotas.html
./usr/share/doc/proftpd-1.3.3c/howto/Regex.html
./usr/share/doc/proftpd-1.3.3c/howto/Rewrite.html
./usr/share/doc/proftpd-1.3.3c/howto/SQL.html
./usr/share/doc/proftpd-1.3.3c/howto/SSH.html
./usr/share/doc/proftpd-1.3.3c/howto/Scoreboard.html
./usr/share/doc/proftpd-1.3.3c/howto/Sendfile.html
./usr/share/doc/proftpd-1.3.3c/howto/ServerType.html
./usr/share/doc/proftpd-1.3.3c/howto/Stopping.html
./usr/share/doc/proftpd-1.3.3c/howto/TLS.html
./usr/share/doc/proftpd-1.3.3c/howto/Testing.html
./usr/share/doc/proftpd-1.3.3c/howto/Timestamps.html
./usr/share/doc/proftpd-1.3.3c/howto/Tracing.html
./usr/share/doc/proftpd-1.3.3c/howto/Translations.html
./usr/share/doc/proftpd-1.3.3c/howto/Umask.html
./usr/share/doc/proftpd-1.3.3c/howto/Upgrade.html
./usr/share/doc/proftpd-1.3.3c/howto/Versioning.html
./usr/share/doc/proftpd-1.3.3c/howto/Vhost.html
./usr/share/doc/proftpd-1.3.3c/howto/VirtualUsers.html
./usr/share/doc/proftpd-1.3.3c/howto/index.html
./usr/share/doc/proftpd-1.3.3c/license.txt
./usr/share/doc/proftpd-1.3.3c/mod_sample.c
./usr/share/doc/proftpd-1.3.3c/modules
./usr/share/doc/proftpd-1.3.3c/modules/mod_auth_file.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_auth_pam.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_cap.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_ctrls.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_delay.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_dso.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_facl.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_facts.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_ident.html
./usr/share/doc/proftpd-1.3.3c/modules/mod_lang.html
./usr/share/doc/proftpd-1.3.3c/rfc
./usr/share/doc/proftpd-1.3.3c/rfc/draft-bonachea-sftp-00.txt
./usr/share/doc/proftpd-1.3.3c/rfc/draft-ietf-ftpext-sec-consider-02.txt
./usr/share/doc/proftpd-1.3.3c/rfc/draft-somers-ftp-mfxx-03.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc0959.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc2228.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc2389.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc2428.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc2640.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc3659.txt
./usr/share/doc/proftpd-1.3.3c/rfc/rfc4217.txt
./usr/share/doc/proftpd-1.3.3c/sample-configurations
./usr/share/doc/proftpd-1.3.3c/sample-configurations/PFTEST.conf.in
./usr/share/doc/proftpd-1.3.3c/sample-configurations/PFTEST.group
./usr/share/doc/proftpd-1.3.3c/sample-configurations/PFTEST.install
./usr/share/doc/proftpd-1.3.3c/sample-configurations/PFTEST.passwd
./usr/share/doc/proftpd-1.3.3c/sample-configurations/PFTEST.shadow
./usr/share/doc/proftpd-1.3.3c/sample-configurations/anonymous.conf
./usr/share/doc/proftpd-1.3.3c/sample-configurations/basic.conf
./usr/share/doc/proftpd-1.3.3c/sample-configurations/complex-virtual.conf
./usr/share/doc/proftpd-1.3.3c/sample-configurations/mod_sql.conf
./usr/share/doc/proftpd-1.3.3c/sample-configurations/virtual.conf
./usr/share/doc/proftpd-1.3.3c/xferstats.holger-preiss
./usr/share/man/man1/ftpcount.1.gz
./usr/share/man/man1/ftptop.1.gz
./usr/share/man/man1/ftpwho.1.gz
./usr/share/man/man5/xferlog.5.gz
./usr/share/man/man8/ftpdctl.8.gz
./usr/share/man/man8/ftpscrub.8.gz
./usr/share/man/man8/ftpshut.8.gz
./usr/share/man/man8/proftpd.8.gz
./var/run/proftpd
13676 blocks
and
# grep proftpd.conf /usr/local/directadmin/custombuild/build
PROFTPD_CONFIGURE=configure/proftpd/configure.proftpd
if [ -e custom/proftpd/configure.proftpd ]; then
        PROFTPD_CONFIGURE=custom/proftpd/configure.proftpd
        rm -f /etc/proftpd.conf.old
        cp /etc/proftpd.conf /etc/proftpd.conf.old
                if [ "${PROFTPD_CONFIGURE}" = "configure/proftpd/configure.proftpd" ]; then
        rm -f /usr/local/etc/proftpd.conf
        ln -sf /etc/proftpd.conf /usr/local/etc/proftpd.conf
        perl -pi -e 's/DisplayFirstChdir/DisplayChdir/' /etc/proftpd.conf
