R remco30 Verified User Joined Sep 29, 2010 Messages 5 Apr 10, 2012 #1 Hi, i am searching for a way to manually decide if domains/users get the phpmyadmin alias but i cant find a way to do this. Can someone help me out or point me in a right direction? thanks
scsi Verified User Joined Aug 19, 2008 Messages 4,179 Apr 11, 2012 #2 Its a global alias you cant just add it for certain users and not others. You would have to figure out some work around with a password or something.
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,167 Location www.poralix.com Apr 12, 2012 #3 Hello, Even if you remove the link, your users having access to connect to MySQL server will able be to use phpMyAdmin on http://IP/phpmyadmin/ remco30 said: Hi, i am searching for a way to manually decide if domains/users get the phpmyadmin alias but i cant find a way to do this. Can someone help me out or point me in a right direction? thanks Click to expand...
N Nerigal Verified User Joined Jul 6, 2009 Messages 111 Jun 8, 2012 #4 i think it could be possible in the vhost template if the DA user package does not allow any mysql database then do rewrite phpmyadmin to ./ and any request do to Apache from direct ip should have a rule Order allow,deny Deny from all Allow webmaster ip and btw i dont event think mysql database space is calculated in the total amount of used space ( each user ).
