Fatal Error on Admin Page
divinelighting
At the bottom under Extra Features Section
Fatal error: Directive 'allow_call_time_pass_reference' is no longer available in PHP in Unknown on line 0
Possibly correlated with latest directadmin update 1.403
Do you have any 3rd plugins installed in Directadmin? Will you show a screenshot of a page with that error?
Well, depend, if you changed php release and you are not using a default skin you have to update or skin or downgrade php to older release.
If you are using a default skin you need to probably re-download the skin cause has not been updated, or, maybe directadmin is not up2date.
Regards
That's it, I have updated php. How to fix?
You did not answer my questions. Here they are:
Note, default Directadmin with default skins does not give such an error. So you must be using something from 3rd parties.
No 3rd party plugins that I am aware of. Screenshot attached.
You might be able to just turn off error display in php.ini
Yes, directadmin is up to date.
Now I have another issue, probably unrelated. Yesterday I accidentally deleted some web site files from /domains/MYDOMAIN.COM/
I deleted folders public_ftp, .httpasswd, files private_html and some public_html files. I restored everything from yesterday's backup and all is good with one wierd exception: SSL is not working. The website is www.divinelighting.com and I disabled secure checkout because of the issue. However, you can see the error by changing the path to https. When that is done, a page with only "./public_html" is displayed.
This is what I was told on the zencart forum:
Firstly, I can confirm that your site is now fully functional without SSL. I suggest you keep it that way until the issue has been resolved, because it will still allow sales (and since you use PayPal express you probably don't *need* SSL anyway).
Secondly, it is not a cache or sessions issue. This is easily confirmed by pointing your browser to any page on your site and using https:// rather than just http://
Example:
https://www.divinelighting.com shows the error
http://www.divinelighting.com works just fine.
By using these URL's explicitly is effectively showing that the problem has nothing to do with your zencart configuration files, or its session management. It could (in theory) be a cache problem, but trying URL's that I know wouldn't exist (eg https://www.divinelighting.com/wally) is a good way of elimitating this possibilty (if a page has never been requested before, it could never be in a cache).
In other words, with just one single test to https://www.divinelighting.com/wally has elimiinated many possible causes. (including URL rewrites/redirects)
OK, so here's the cruncher... I still can't think of *anything* that would cause the symptoms that are being presented. At the VERY LEAST I would have expected https://www.divinelighting.com/wally to redirect me to a page not found error (as it does when I attempt http://www.divinelighting.com/wally)
So, where to from here? I really don't think this problem has anything to do with you or zencart. I'm thinking it has something to do with the server configuration itself. For reasons that I can't explain, your SSL server simply isn't doing what an SSL server should be doing. It appears to have no concept of what files it should be serving up and the fact that it is showing the folder name ./public_html can only be caused by a server configuration error.
You will need to contact your host for help with this one. It is NOT something that you can fix yourself. Please feel free to post a copy of this posting when asking your host for help. It'll help prevent them feeding you billshot and suggesting that it is a zencart (or similar) configuration error.
DO mention about the accidental deletion of your files because there *may* have been a 'symbolic link' (or similar) *hidden* in your public_html folder that got accidently deleted, and if so, they'll know about it and will be able to quickly restore it for you without any further investigationing :)
Either way, it is stil lsomething that only your host can fix.
I think the ssl problem is something to do with pivate_html, as it contains exactly the phrase "./public_html"
Solved the SSL problem. Symbolic link was broken. Found solution here: http://www.webhostingtalk.com/archive/index.php/t-315593.html
Deleted private_html and then executed
ln -s /home/USERNAME/domains/DOMAIN.COM/public_html /home/USERNAME/domains/DOMAIN.COM/private_html
As far as the php issue goes, if there is no obvious solution I will not worry about it, as I will be moving to a new server soon.
For reinstall the skin you should try:
cd /usr/local/directadmin/data/skins
./packskins.sh
Sorry for didnt reply to SSL problem, timezone difference i suppose :D i was sleeping, if not, was an easy solution ^^
Regards
I guess, you're running PHP 5.4. So follow this instructions made by Martynas Bendorius:
You should comment out allow_call_time_pass_reference in php.ini, because it's no longer available. The following should fix it:
perl -pi -e 's/^allow_call_time_pass_reference/;allow_call_time_pass_reference/' /usr/local/lib/php.ini
http://www.directadmin.com/forum/showthread.php?t=43032&p=218391#post218391
