Suurbier
- Apr 23, 2007
Maybe it is a good idea to improve the output of build versions, now it shows
If something is ready for an update you need to scroll to see if something is ready to update. Maybe it is a better idea to throw out a last line with the number of updates like this
It is very easy to add this feature and helps a lot of administrators that manually need to check and update DA servers.
Latest version of RoundCube webmail: 0.7.2
Installed version of RoundCube webmail: 0.7.2
Latest version of phpMyAdmin: 3.5.1-all-languages
Installed version of phpMyAdmin: 3.5.1-all-languages
Latest version of SquirrelMail: 1.4.22
Installed version of SquirrelMail: 1.4.22
1 update(s) found, run ./build update_versions to update
