I have change IP, but wrong netmask
  • Thread starter Thread starter wm20472
  • Start date Start date
W
wm20472
Guest
I remove my server to new rack, IP & subnet mark have beed changed.
In DA, I have change IP, but wrong netmask.
How I can change netmask? (from 255.255.255.192 >> 255.255.255.224)
You can change it in the appropriate file in the /usr/local/directadmin/data/admin/ips/ directory.
If it's the main server IP# you should probably also change it in whatever system your OS distribution uses to set up networking.
Then you should restart networking, and afterwards run the /usr/local/directadmin/scripts/startips command.
What do you mean by this:you should probably also change it in whatever system your OS distribution uses to set up networking.
And how can I change it.
If you dont know how to change your networking configuration in your Linux OS why are you running a production server?
Because DirectAdmin just makes it too easy :D
badheeu,
What everybody means here is that you should change the netmask both in DirectAdmin, but also in the settings of your Linux operating system.
