Error Install DirectAdmin
reza303
Hello
install DairectAdmin ( end install but not Useradmin and pass )
and error :
Apache will not run
./install.sh: line 345: ./directadmin: cannot execute binary file
System Security Tips:
http://help.directadmin.com/item.php?id=247
* Cannot find /usr/local/directadmin/conf/directadmin.conf
* Please see this guide:
* http://help.directadmin.com/item.php?id=267
[root@linux ~]# service httpd status
httpd is stopped
[root@linux ~]# service httpd start
Starting httpd: [Sun Jun 24 05:11:49 2012] [warn] module php5_module is already loaded, skipping
httpd: Syntax error on line 109 of /etc/httpd/conf/httpd.conf: Syntax error on line 21 of /etc/httpd/conf/extra/httpd-vhosts.conf: Could not open configuration file /etc/httpd/cnf/ips.conf: No such file or directory
[root@linux ~]# http://help.directadmin.com/item.php?id=267/sbin/service httpd restart
-bash: http://help.directadmin.com/item.php?id=267/sbin/service: No such file or directory
[root@linux ~]# /sbin/service httpd restart
Stopping httpd: [FAILED]
Starting httpd: [Sun Jun 24 06:30:40 2012] [warn] module php5_module is already loaded, skipping
httpd: Syntax error on line 109 of /etc/httpd/conf/httpd.conf: Syntax error on line 21 of /etc/httpd/conf/extra/httpd-vhosts.conf: Could not open configuration file /etc/httpd/conf/ips.conf: No such file or directory
Sample :
please help
Error says: Cannot execute binary file.
Is your directadmin license which you used set to the Operating system and version that you are using on that server (OS and 32-bit/64-bit)?
If not, ask sales to adjust your license file with the correct operating system and version and then you can try again.
This is also explained in your error message of the screenshot, look here:
Centos
5
64 bit
Have you checked if the license is set correctly for match your OS?
This error is usually related to a os missmatch.
Regards
