B bukalik New member Joined Sep 20, 2012 Messages 4 Sep 20, 2012 #1 upgrade php 5.3.16 DA custombuild 1.39.1 how to safely upgrade php 5.3.6 to php 5.3.16? mysql5.1 phpmyadmin3.4 thank you
scsi Verified User Joined Aug 19, 2008 Messages 4,340 Sep 20, 2012 #2 Code: cd /usr/local/directadmin/custombuild ./build update ./build clean ./build update_versions
B bukalik New member Joined Sep 20, 2012 Messages 4 Sep 20, 2012 #3 do i have to download php 5.3.16 package to custombuild dir?? like here? http://reference.xarray.org.uk/prod...etbeans-network/directadmin-php-upgrade-p-309 thanks
Suurbier Verified User Joined Apr 23, 2007 Messages 217 Sep 20, 2012 #4 bukalik said: do i have to download php 5.3.16 package to custombuild dir?? like here? http://reference.xarray.org.uk/prod...etbeans-network/directadmin-php-upgrade-p-309 thanks Click to expand... No, custombuild does everything for you. Run the commands scsi posted.
B bukalik New member Joined Sep 20, 2012 Messages 4 Sep 20, 2012 #5 for god sake, how do i know that script will install php 5.3.16 not 5.4.x????
scsi Verified User Joined Aug 19, 2008 Messages 4,340 Sep 20, 2012 #6 Look in options.conf and see what php version is set to. If it was 5.3 before it is not going to mysteriously install 5.4 unless you changed the setting in options.conf.
B bukalik New member Joined Sep 20, 2012 Messages 4 Sep 20, 2012 #7 will it overwrite old php/apache configs ini files and settings?? do i need to take a backup?? what if i do not want to upgrade postfix dovecot and other software? thank you
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,233 Location www.poralix.com Sep 22, 2012 #8 Are you sure, you're running Postfix? Directadmin supports only Exim. To update only PHP run this: Code: cd /usr/local/directadmin/custombuild ./build update ./build clean ./build php d That will upgrade only PHP. And no, it does not overwrite any existing configs on your server. p.s. Backups are always good to have.
