Some botnet is trying to POST a php file?
DJSnels
Sinds a day or 2 one of my domains is using a loat of bandwidth.
The Apache access logs have thousends of these loggings from many different IP-adresses:
212.246.140.250 - - [26/Sep/2012:19:58:55 +0200] "POST /images/g.php HTTP/1.1" 404 595 "-" "-"
94.170.132.240 - - [26/Sep/2012:19:59:00 +0200] "POST /images/g.php HTTP/1.1" 404 595 "-" "-"
77.168.207.16 - - [26/Sep/2012:19:59:04 +0200] "POST /images/g.php HTTP/1.1" 404 595 "-" "-"
Is there anything that can be done to prevent this?
What are these requests trying to do?
Then you might want to look into blocking urls with .htaccess
There should be a ton of guides on google.
You might be able to try something like this in .htaccess:
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_URI} /images/g\.php [NC]
RewriteRule ^.*$ - [F]
</IfModule>
I still am not sure what its going to do for helping bandwidth though. You might need to look at fail2ban and a custom rule.
Here's what I advise my clients to do:
To prevent execution of PHP code inside your image and cache directories, which is mostly where hackers will upload their phishing scripts, simply paste this code into a .htaccess file inside your image/cache directories:
<Files .htaccess>
order allow,deny
deny from all
</Files>
php_flag engine off
Options -ExecCGI
<FilesMatch "\.(php|pl|sh|cgi)$">
<Limit GET PUT POST>
order deny,allow
deny from all
</Limit>
</FilesMatch>
or
# stop scripts from running from the folder
IndexIgnore *
Options All -Indexes
# Secure directory by disabling script execution
AddHandler cgi-script .php .php2 .php3 .php4 .php5 .php6 .php7 .php8 .pl .py .jsp .asp .htm .html .shtml .sh .cgi
Options -ExecCGI
# Don't show this file, that would be bad as well!
<Files .htaccess>
order allow,deny
deny from all
</Files>
As an admin.. is there a way to just push those filtering rules inside the main httpd.conf
so every user on a share host will inherit of it ?
