Cleartext Login Permitted
RS-Lee
We're currently experiencing the following issue holding us back with PCI compliance:
"The remote mail server allows cleartext logins. Impact: The remote host is running an SMTP server that advertises that it allows cleartext logins over unencrypted connections. "
I was wondering if anyone else is seeing this issue if so what resolution did you utilise ?
Many thanks :-)
So change your exim to only allow ssl connections. Search the forums.
