S shayhalif Verified User Joined Oct 4, 2012 Messages 5 Oct 4, 2012 #1 Hi on the System stats I can see that I have under / 228GB available. but on the Disk space allocated I can see just 43700 . why can't I use all the Disk space for hosting ?
nobaloney NoBaloney Internet Svcs - In Memoriam † Joined Jun 16, 2003 Messages 24,878 Location California Oct 4, 2012 #2 You can only host using space available in /home (presuming separate partitions). Jeff
S shayhalif Verified User Joined Oct 4, 2012 Messages 5 Oct 5, 2012 #3 how do I set /home size hi right now the /home is a directory inside the / how can I set it to be more then 43700 ?
SeLLeRoNe Super Moderator Joined Oct 9, 2004 Messages 6,419 Location A Coruña, Spain Oct 5, 2012 #4 You need or to fix your patitions or add a second drive and mount it as /home (renaming the current one to /home2 and once mounted the new moving all files). Regards
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,149 Location www.poralix.com Oct 5, 2012 #5 shayhalif said: hi right now the /home is a directory inside the / how can I set it to be more then 43700 ? Click to expand... Hello, Sell more accounts to fill your HDD. For now you've sold only 43700 Mb HDD. "Allocated" means a summary of sold disc spaces, nothing more.
