Install PHP with - T1Lib and XPM support
Artis
Zagreb - Croatia
Hi to all,
I'm new to DA, and from forum I see that i must use custombuild for PHP options (T1Lib, XPM).
I use centos 6.3, PHP 5.3.18 (CGI) and suPHP 0.7.1.
How i can install T1Lib and XPM. What file do I need to edit.
Best regards
EDIT:
I did:
HTML:
 mkdir -p custom/ap2
 cp configure/ap2/configure.php5 custom/ap2/configure.php5
 nano custom/ap2/configure.php5
after that i add --enable-t1lib
and final
HTML:
./build clean
./build php
service httpd restart
and I do not have t1lib on my system :confused:
Any hint
EDIT2:
My nano /usr/local/directadmin/custombuild/custom/ap2/configure.php5
HTML:
#!/bin/sh
./configure \
        --with-apxs2 \
        --with-curl=/usr/local/lib \
        --with-gd \
        --with-ttf \
        --with-gettext \
        --with-jpeg-dir=/usr/local/lib \
        --with-freetype-dir=/usr/local/lib \
        --with-kerberos \
        --with-openssl \
        --with-mcrypt \
        --with-mhash \
        --with-mysql \
        --with-mysqli \
        --with-pdo-mysql \
        --with-pcre-regex=/usr/local \
        --with-pear \
        --with-png-dir=/usr/local/lib \
        --with-xsl \
        --with-zlib \
        --with-zlib-dir=/usr/local/lib \
        --with-iconv=/usr/local \
        --enable-bcmath \
        --enable-calendar \
        --enable-exif \
        --enable-ftp \
        --enable-gd-native-ttf \
        --enable-magic-quotes \
        --enable-safe-mode \
        --enable-soap \
        --enable-t1lib \
        --enable-sockets \
        --enable-mbstring \
        --enable-zip \
        --enable-wddx
For PHP-CGI (suPHP) you should copy
/usr/local/directadmin/custombuild/configure/suphp/configure.php5
to
/usr/local/directadmin/custombuild/custom/suphp/configure.php5
and modify /usr/local/directadmin/custombuild/custom/suphp/configure.php5
Thanks you, for this
Another question is, if I enable t1lib and xpm (xpm is required folder dir) I try to find xpm dir but it's not on the server. Can I use yum install to install xpm and after that enable it in config ? Will I break DA ?
Best regards
EDIT:
Error what i have
HTML:
configure: error: libXpm.(a|so) not found.
*** There was an error while trying to configure php. Check the custom/suphp/configure.php5 file
[root@server custombuild]# yum install libXpm
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: ftp.hosteurope.de
 * extras: ftp.hosteurope.de
 * updates: ftp.hosteurope.de
base        | 3.7 kB     00:00
extras        | 3.5 kB     00:00
updates        | 3.5 kB     00:00
Setting up Install Process
Package libXpm-3.5.8-2.el6.x86_64 already installed and latest version
Nothing to do
My /usr/local/directadmin/custombuild/custom/suphp/configure.php5
HTML:
#!/bin/sh
"./configure" \
"--prefix=/usr/local/php5" \
"--enable-force-cgi-redirect" \
"--enable-fastcgi" \
"--with-config-file-path=/usr/local/etc/php5/cgi" \
"--with-curl=/usr/local/lib" \
"--with-gd" \
"--with-gettext" \
"--with-jpeg-dir=/usr/local/lib" \
"--with-freetype-dir=/usr/local/lib" \
"--with-kerberos" \
"--with-mcrypt" \
"--with-mhash" \
"--with-mysql=/usr" \
"--with-mysqli=/usr/bin/mysql_config" \
"--with-pcre-regex=/usr/local" \
"--with-pdo-mysql=/usr" \
"--with-pear=/usr/local/lib/php" \
"--with-png-dir=/usr/local/lib" \
"--with-xsl" \
"--with-zlib" \
"--with-zlib-dir=/usr/local/lib" \
"--with-openssl" \
"--with-xpm-dir=/usr" \
"--with-iconv=/usr/local" \
"--with-t1lib" \
"--enable-bcmath" \
"--enable-calendar" \
"--enable-exif" \
"--enable-ftp" \
"--enable-gd-native-ttf" \
"--enable-magic-quotes" \
"--enable-soap" \
"--enable-sockets" \
"--enable-mbstring" \
"--enable-zip" \
"--enable-wddx"
If installation of libXpm-devel does not help (as suggested by user scsi), then you might need to install 32 bit versions of these two packages.
You would have to search the filesystem where the .so files are. I would just try /usr/local
If not you could try:
find / -type f -name libXpm\*so
@Scsi I try to search but i have nothing
HTML:
[root@server custombuild]# find / -type f -name libXpm\*so
HTML:
Package libXpm-devel-3.5.8-2.el6.x86_64 already installed and latest version
Nothing to do
Oh its cause it doesnt end in .so its .so.XXX
[root@mon1 ~]# find / -type f -name libXpm*
/usr/lib/libXpm.so.4.11.0
You might want to try /usr/lib or /usr/lib64
Thanks for help
But i have no success
HTML:
HTML:
#!/bin/sh
"./configure" \
"--with-gd" \
"--with-gettext" \
"--with-kerberos" \
"--with-mcrypt" \
"--with-mhash" \
"--with-xsl" \
"--with-zlib" \
"--with-openssl" \
"--with-xpm-dir=/usr/lib64" \
"--with-t1lib-dir=/usr/share" \
"--enable-bcmath" \
"--enable-t1lib" \
"--enable-exif" \
"--enable-ftp" \
"--enable-soap" \
"--enable-zip" \
"--enable-wddx"
HTML:
[root@server custombuild]# find / -type f -name libXpm*
/usr/lib64/libXpm.so.4.11.0
any hint ?
You might want to look at the config.log in the php source folder and see what its searching for.
I use google and logs, and i manage to enable T1lib, but XPM support i can't enable.
Google say that I must have DIR something like this /usr/X11R6
On CentOS 6 (x64) I don't have that dir, what yum lib to install to get dir something like that ?
Best regards
