Backup failure
Mattie
I recentley transferd my directadmin from my old server to a new VPS. I used the "admin backup and transfer" function and it worked perfectley.
However for some strange reason i can not use the backup function anymore!
Error while backing up database admin_mcNW
Error writing settings file for admin_mcleeg
Error while backing up database admin_mcleeg
Error while backing up database admin_mcleeg: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_mcleeg.sql
Error writing settings file for admin_mctemp
Error while backing up database admin_mctemp
Error while backing up database admin_mctemp: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_mctemp.sql
Error writing settings file for admin_mctest
Error while backing up database admin_mctest
Error while backing up database admin_mctest: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_mctest.sql
Error writing settings file for admin_minecraft
Error while backing up database admin_minecraft
Error while backing up database admin_minecraft: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_minecraft.sql
Error writing settings file for admin_pmcjoomla
Error while backing up database admin_pmcjoomla
Error while backing up database admin_pmcjoomla: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_pmcjoomla.sql
Error writing settings file for admin_pmcwp
Error while backing up database admin_pmcwp
Error while backing up database admin_pmcwp: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_pmcwp.sql
Error writing settings file for admin_projectmc
Error while backing up database admin_projectmc
Error while backing up database admin_projectmc: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_projectmc.sql
Error writing settings file for admin_stefan
Error while backing up database admin_stefan
Error while backing up database admin_stefan: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_stefan.sql
Error writing settings file for admin_upload
Error while backing up database admin_upload
Error while backing up database admin_upload: The sql file is 0 bytes in size: /home/admin/admin_backups/admin/backup/admin_upload.sql
Error copying ./data/users/admin/history to /home/admin/admin_backups/admin/backup/history : <b>User disk quota exhausted when trying to create /home/admin/admin_backups/admin/backup/history</b>
Unable to create the directory /home/admin/admin_backups/admin/backup/history
Error writing /home/admin/admin_backups/admin/backup/xxx.nl/domain.conf to insert local_domain & private_html_is_link: Unable to stat /home/admin/admin_backups/admin/backup/1ssss.nl/domain.conf.temp for filesize after write
ConfigFile::removeFile(/home/admin/admin_backups/admin/backup/1ssss.nl/domain.conf) filename does not match
Error writing /home/admin/admin_backups/admin/backup/xxx.nl/domain.conf to insert local_domain & private_html_is_link: Unable to stat /home/admin/admin_backups/admin/backup/ssss.nl/domain.conf.temp for filesize after write
ConfigFile::removeFile(/home/admin/admin_backups/admin/backup/ssss.nl/domain.conf) filename does not match
Error writing /home/admin/admin_backups/admin/backup/mattie-xxx.nl/domain.conf to insert local_domain & private_html_is_link: Unable to stat /home/admin/admin_backups/admin/backup/sssss-ssss.nl/domain.conf.temp for filesize after write
ConfigFile::removeFile(/home/admin/admin_backups/admin/backup/ssss-ssss.nl/domain.conf) filename does not match
Error writing /home/admin/admin_backups/admin/backup/xxx.nl/domain.conf to insert local_domain & private_html_is_link: Unable to stat /home/admin/admin_backups/admin/backup/ssss-ssss.nl/domain.conf.temp for filesize after write
Error writing /home/admin/admin_backups/admin/backup/apache_owned_files.list : Error writing /home/admin/admin_backups/admin/backup/apache_owned_files.list.  Disk might be full.
ConfigFile::removeFile(/home/admin/admin_backups/admin/backup/apache_owned_files.list) filename does not match
Error Compressing the backup file /home/admin/admin_backups/admin/backup/home.tar.gz :
gzip: stdout: Disk quota exceeded
/bin/tar: /home/admin/admin_backups/admin/backup/home.tar.gz: Wrote only 8192 of 10240 bytes
/bin/tar: Error is not recoverable: exiting now
Error Compressing the backup file admin.root.admin.tar.gz :
/bin/tar: /home/admin/admin_backups/admin/admin.root.admin.tar.gz: Cannot write: Broken pipe
<13:41:45>
User xxxx has been backed up. <13:41:47>
User xxxx has been backed up. <13:42:05>
User xxxx has been backed up. <13:42:09>
The disk is not full. At the moment i'm using about 12GB and the total HDD size of my vps is 50GB.
DA info:
Compiled on Debian 6.0
Compile Date Nov 28 2012, 02:24:30
Server Version 1.42.1
Any idea what could be the problem?
Apparently is a problem with user quota, not disk space.
I dont think is admin user quota, i more thinki about single user are backedup quota... the backup keep the owner for a better restore so probably those file increase the usage of those users and the system quota block it.
You should think to set admin_backups path in a separated partition without quota enabled.
Regards
Well it would be strange if it was a quote issue:
The backup is started from the build-in "admin" account. That account should have unlimited disk space! As far as i can remember i never had any problems with backups untill i moved now to a VPS.
Is it possible to disable the quota check?
Check with quota -v admin if the user quota of admin is the problem.
Well i found it.
I was looking into things and it seems my VPS host has set my disk space to 50 gb (according to the admin panel) however DA only reported it as 20GB. Now i really have 50GB and the issue is resolved, thanks for your help all!
@SeLLeRoNe,
Just a remark.
Directadmin disables temporary user quotas for making backups. So in most cases that should not be an issue.
