eAccelerator issue
blog
Hi
I have centos 6 php 5.3.19 install eAccelerator I have this error
eAccelerator: Unable to change cache directory /var/cache/eaccelerator permissions
permissions are set as 0777 and I have restarted the server
How I can fix issue?
many thanks.
Check the permissions and ownership for both /var and for /var/cache.
Thank you for respond
I should change perm to 0777 for /var and /var/cache ?
What is ownership for both?
check perm and ownership
/var 0755 root
/var/cache 0755 root
/var/cache/eaccelerator 0777 root
Since I don't use eaccelerator, someone else will need to respond to your question.
Here what the official wiki says:
Step 4. Creating cache directory
One last very important step is creating the cache directory that you configured in the previous step. The default value is /tmp/eaccelerator It's easy because it's writable to everyone, but it isn't very smart because on a lot of systems this directory is cleaned on reboot. A better place would be /var/cache/eaccelerator. Create the directory and make sure it's writable for the user eAccelerator runs under (usually the user which you webserver runs as).
A safe bet is making it world writable. A safer and cleaner way would be to change the owner of the directory to the same user PHP runs as (most of the time the same user as Apache or Lighttpd) and set 0644 permissions.
The lazy way:
mkdir /tmp/eaccelerator
chmod 0777 /tmp/eaccelerator
https://github.com/eaccelerator/eac...omSource#wiki-Step_4_Creating_cache_directory
So, if you use /var/cache/eaccelerator, then it also should be chowned to 0777.
