IT_Architect
- Feb 27, 2006
Can I keep DirectAdmin up to date on a spare VM that has an expired license?
I've used nothing but virtual machines for the past 4 1/2 years. I want to do updates on VMs that are not active so there are no service interruptions, then switch the active and inactive VMs and their IP addresses, and then refresh the license on the newly activated VM. That would mean while the spare is being updated, it would use an IP that is not registered with DA. I wouldn't need access the control panel on the spare VM, but I would want to be able to update DA and its related software. Will that work?
Another thing that would be very useful is to be able to bring a VM up under a different IP to do backups and restores.
