problem backup
groomy
AUGNY (France)
hi, i have this message error after CRON backup :
ncftpput /home/tmp/admin/user.haiko.sexyweb.tar.gz: socket write error.
<5:56:09>
Could not read reply from control connection -- timed out.
ncftpput /home/tmp/admin/user.admin.webonline.tar.gz: data transfer timed out.
<6:01:58>
User yatoula has been backed up. <6:02:15>
Remote write timed out.
ncftpput /home/tmp/admin/user.admin.yatoula.tar.gz: data transfer timed out.
<6:02:41>
where is the problem ?
Probably the system could not connect to the ftp server.
If you have a separate ftp server check this first.
May be your firewall closed the port, Or your FTP server has problem. I recommend you to contact to your Data Center ;)
I have my firewall (csf) in DA, but what is the port ?
Hello, still same problems with the CRON job and my error messages
User admin has been backed up. <5:00:02>
ncftpput /home/tmp/admin/admin.root.admin.tar.gz: could not send file to remote host.
<5:00:27>
User augrandfre has been backed up. <5:00:30>
ncftpput /home/tmp/admin/user.haiko.augrandfre.tar.gz: data transfer timed out.
<5:00:56>
User baticoffre has been backed up. <5:00:59>
ncftpput /home/tmp/admin/user.haiko.baticoffre.tar.gz: data transfer timed out.
<5:01:25>
It's a disk with ncftp , i send email in OVH
thank you I looking for the solution.
ok, but the problem is in the csf, IPv4 have port 20 and 21 IPv6 not.
I change and now it's good. Just a error with a account.
