Deleting Main User E-mails - Guideline Needs Update
orkinoks
I tried to delete main user e-mails using this guideline.
http://help.directadmin.com/item.php?id=433
The command to delete the main user e-mails is :
rm -f `find /home/$i/Maildir -mtime +${OLD_THAN_DAYS} | grep -E '/cur/|/new/'`
But I get "line 12: /bin/rm: Argument list too long" error. Clearly there is a directory with more number of e-mails then rm can handle.
According to this guideline :http://help.directadmin.com/item.php?id=327
We need to be using find . -type f -delete
Based on this two info, could someone re-write the line which will delete main user e-mails and confirm that it is all correct before I do something horrible
You need to make script to do that, like the following I did:
To works fine, First must complete that :p
find $directory -type f -name '*' -exec mv
{} $directory2/. \;
#!/bin/sh
#Deletes emails older than this number of days
OLD_THAN_DAYS=30
for i in `ls /usr/local/directadmin/data/users`; do
       if [ ! -d /home/$i/Maildir ]; then
               continue;
       fi
find $directory -type f -name '*' -exec mv {} $directory2/. \;
done;
exit 0;
I got
find: missing argument to `-exec'
clean_mail.sh: line 2: {}: command not found
with your script.
Cause he did pasted not correctly, use this:
#!/bin/sh
OLD_THAN_DAYS=30
               continue;
       fi
done;
exit 0;
Is just needed to bring second line as continue of the first.
Regards
Thanks @SeLLeRoNe
I told you guys you must com pleat at first. So I think you got the error because of file size.
Use following code, It'll fix your problem. :cool:
#!/bin/sh
OLD_THAN_DAYS=30
               continue;
       fi
find /home/$i/Maildir -type f -name '*' -exec rm {} \;
done;
exit 0;
Hi Sellerone,
thanks for the warning, I did not notice the mistake.
However I got
line 13: /bin/rm: Argument list too long
error with your script too.
#!/bin/sh
OLD_THAN_DAYS=30
               continue;
       fi
done;
exit 0;
Regards
I don't know why but this one also gives argument list too long error.
As of my understanding, we have get rid of rm command between if - fi.
Thanks @SeLLeRoNe
#!/bin/sh
OLD_THAN_DAYS=30
               continue;
       fi
done;
exit 0;
Did you paste on your command run?
If so, yes it is. Don't anymore and follow the bellow instruction:
1. type the following code to make a file
nano delmail
2. copy the following cod :
#!/bin/sh
OLD_THAN_DAYS=30
               continue;
       fi
done;
exit 0;
3. press crtl + o to save file
4. press crtl + x to exit
5. type the following code
chmod 755 delmail
./delmail
