syslint
- Oct 24, 2010
About Danginx:
Danginx or Direct Admin nginx plugin is an Nginx server integration plugin for Directadmin servers. This plugin will increase your server performance and decrease server loads cased by apache web server.
Project Home Page : http://danginx.com/
Documentation : http://wiki.sysvm.com/DirectAdminNginx
Forum url : http://forum.syslint.com/
How Nginx will help your Directadmin server to increase the performance ?
Nginx is known for its high performance, stability, rich feature set, simple configuration, and low resource consumption.
Unlike traditional servers, Nginx doesn't rely on threads to handle requests. Instead it uses a much more scalable event-driven (asynchronous) architecture. This architecture uses small, but more importantly, predictable amounts of memory under load.
Even if you don't expect to handle thousands of simultaneous requests, you can still benefit from Nginx's high-performance and small memory footprint. Nginx scales in all directions: from the smallest VPS all the way up to clusters of servers.
Some Features of Danginx
High Performance : Nginx will work as a front end reverse proxy of your Directadmin server along with apache. Which will increase the performance due to the software architecture.
Protection Against Malicious attacks : Nginx will only pass true http requests and protect against attacks like DDOS from your server.
100% compatible with Directadmin : Danginx is 100% compatible with Directadmin. It have autoinstaller , autoupdate and uninstaller scripts which will make your job easy to integrate it.
GZIP compression , Save bandwidth : Danginx is integrated with GZIP compression. You can enable and disable this feature.You can also set the compression lever from 1 to 9.
New Features :
****Danginx is free with our Directadmin Server Management Plans***
New Features :
- Support Ipv6
- Support apache 2.4
- Install Any version of Nginx via "installnginx" script
- Install any nginx modules via autoconfigure in /etc/danginx/configure.sh
- Reseller control panel and API
- WHMCS Module for Resellers
