Uploading files
PaulGJ
To which do I need to upload my files with FTP? I have tried all them, but no luck.
Thank you in advance,
Best regards
PaulGJ
Sorry, I forgot to answer in English.
How can I open that file if I double click on it nothing happens. And if I upload the index file there is nothing to see on the web.
Open the directory "domains", then the directory of the hosted domain "your-domain.com" and you will see the public_html. Try uploading the files there.
Thank you, I found it "problem" solved
Paul
