SSL Certificate.
hostingpro
httpd logs
[Tue Mar 26 00:10:03 2013] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Tue Mar 26 00:10:03 2013] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.test.com:443 (/usr/local/directadmin/data/users/amori/httpd.conf:65)
[Tue Mar 26 00:10:03 2013] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Tue Mar 26 00:10:03 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/0.9.8e-fips-rhel5 DAV/2 PHP/5.3.23 configured -- resuming normal operations
[Tue Mar 26 00:11:02 2013] [notice] caught SIGTERM, shutting down
I was going to install SSL cert on my domain but I got many issues. I was playing around and I missed it up so httpd could not start anymore. The website was down and I couldn't either access the admin area.
I was lucky and had a backup of my admin files.
I made a re-install of the server and did a fresh install of directadmin.
I restored the file and almost gave up installing SSL cert.
Now SSL cert. is disabled on my domain by default "cause of the new install"
When I check the log for httpd I see these warnings
httpd logs
I tried to delete these files but httpd goes down when I do that.
What to do now?
Please do not post multiple times. Your original post was ll moderated due to it's content; I just had to delete seven copies.
I'm guessing your Certificate is upladed to the wrong place.
Is this a standard DirectAdmin installation?
What is your domain name?
Is it hosted under a separate username, or the user-level of a reseller account or the user level of an admin account?
While I can't help you with teamviewer, I can install your Certificate for you (as long as you still have a copy of the key file created when you created your CSR), or I can install a new Certificate properly. Usually the latter is a less expensive option, because I can just install one of our issued Certificates a lot more quickly and easily than troubleshooting what you did.
If you're interested in my professional installation or administration services, please contact me by email; my email address is below, in my siglines.
