Aftet update DANGINX 4.1 CSF error
Status
Not open for further replies.
Arie
After updating danginx I can not sign into the control panel of CSF, I get an error appears: Permission denied [User: admin UID: 501] keep this error even after disabling daningx exist.
Has anyone had this same problem and if so, how resolved?
Hi Arie
This error is not caused by DANGINX.
To fix this, please :
1 : Backup csf.conf at
/etc/csf/
2 : Remove csf
#sh /usr/local/directadmin/plugins/csf/scripts/uninstall.sh
3 : Reinstall csf from source
4 : Restore backup csf.conf into
/etc/csf/
5 : Restart csf
#csf -r
6 : Check again & done !
Good luck :)
There must be another solution!
Hi Arie
/etc/csf/
2 : Remove csf
/etc/csf/
5 : Restart csf
#csf -r
Good luck :)
Yeah sure..this leaves an opportunity to hack your server! It's a simple solution, but not the best one. There must be another solution.
Don't try this at home! Because Chinese is hacking you right a way.
Status
