Custombuild 2.0 + mod_ruid2 stable enough?
ditto
I am currently running custombuild 1.2. I am on CentOS 6.4 64 bit, and is running Apache 2.4.4, PHP 5.4.14 with suPHP, and MySQL 5.5.30.
I want to upgrade to custombuild 2.0 and use php cli with mod_ruid2. Is that combination stable enough in custombuild 2.0, or should I wait?
Has anybody done exactly this before me and have some guides? Guides that involve upgrading to custombuild 2.0 and convert to use mod_ruid2 instead of suphp?
I am not going to use more then one php version, I am only going to run php 5.4 version.
I am now reading the cb 2.0 faq http://forum.directadmin.com/showthread.php?t=44743 - I am about to upgrade to cb 2.0 on a server using suphp, same time as I upgrade to cb 2.0 I am going to convert from suphp to mod_ruid2. When reading the faq, I have questions:
1: I am not going to have two php versions, only one. So I understand that I should set php2_release to no - however, this I don't understand:
php2_mode - select the PHP run-mode of php2_release. Possible values: mod_php/fastcgi/suphp/php-fpm (default: php-fpm).
What value should I set on php2_mode when I am only using one php version? Should it be blank without any value, or should I remove the line completely?
2: I don't like to use the command
./build all d
, so after upgrade to custombuild 2.0 and change setting from suphp to mod_ruid2, which applications does I need to ./build in custombuild? Should I ./build all of them? I like to do them one by one.
3: After upgrading to custombuild 2.0, when recompiling php for the first time after upgrade to cb 2.0 and change to mod_ruid2, should I run ./build php n, or should I run only ./build php?
4: Is there anything special that I need to know/do when converting from suphp to mod_ruid2?
5: I see this in the faq:
Major change: mysqlnd (MySQL native driver) is used for MySQL, pdo-MySQL and MySQLi in php configuration.
What consequence does it have for my customers sites when mysqlnd is used in custombuild 2.0? Is there anything I need to know, or will it work same as before?
I am doing it now. in custombuild/options.conf there is this new value wich did not exist in custombuild 1.2:
use_hostname_for_alias=no
What does it mean, what does it do? I have searched without any results.
Edit: Also I found this in custombuild/options.conf:
redirect_host=server.hostname.com
Does that new value replace the value I have in conf/directadmin.conf?:
It seems to me that in cb 2 that value has been moved from conf/directadmin.conf to custombuild/options.conf, should I remove ti from conf/directadmin.conf?
This is a important questions for me, therfor a new reply. In custombuild 2.0 in custombuild/options.conf, there is this new line:
zlib=no
But what should I do about that when upgrading from custombuild 1.2? Should I leave it as "no" and should I then install zlib using yum, or should I set it to "yes"?
Does this mean that default in custombuild 2.0 is to no longer install zlib, but let centos/yum do it instead?
./build all d
1. If php2_release is set to no, php2_mode is ignored.
2. "./build apache", "./build php n" and "./build rewrite_confs" is enough. It might be worth to execute http://help.directadmin.com/item.php?id=354 again before switching to CB 2.0.
3. When step #2 is done, this one can be skipped.
4. Nothing special if you've read the description about mod_ruid2 (what it is and how it works)
5. http://forum.directadmin.com/showthread.php?t=4364 might be worth reading.
Good luck!
These options are just for the httpd-alias.conf file. If you'd like /phpMyAdmin, /webmail and other aliases to redirect to hostname/phpMyAdmin etc., you'd need to set use_hostname_for_alias=yes, then redirect_host would be used for the "hostname" part.
zlib=no
Yes, default (no) is fine, because in all distros it's managed by a package manager (yum in CentOS).
Thank you for all the answers. Currently I have upgraded to custombuild 2.0, but not yet done any rebuild of php etc. I am currently going over the options.conf files etc. before I shall continue.
By the way, custombuild version of mod_ruid2 is 0.9.7. But mod_ruid2 0.9.8 was released in march, it has a security fix. Here is announce: http://sourceforge.net/mailarchive/....sourceforge.net&forum_name=mod-ruid-announce
I have just now sent email to support at directadmin.com asking for them to add the new version. Thanks.
After doing ./build apache I get this error and httpd is down:
chmod 755 /usr/lib/apache/mod_ruid2.so
[activating module `ruid2' in /etc/httpd/conf/httpd.conf]
mod_ruid2 has been installed successfully.
Restarting apache.
Stopping httpd:                                            [  OK  ]
Starting httpd: [Sun Apr 14 23:46:25.910175 2013] [so:warn] [pid 14278] AH01574: module ruid2_module is already loaded, skipping
AH00534: httpd: Configuration error: No MPM loaded.
Should I have done ./build mod_ruid2 first? Should I do ./build mod_ruid2 later on?
I will now continue, and see if the error goes away when doing the rest ...
Okey. After doing the rest of the ./build ..., then the error went away. So seems ok now. Please note that after I did this:
./build apache
./build php n
Then I did also:
./build mod_ruid2
service httpd restart
I think it is needed because I previous in cb 1.2 was using suphp.
Much to check and configure now. My head ... :)
@smtalk, I have a new error when I did ./build apache a second time. Here is the error:
Restarting apache.
Stopping httpd: ./build: line 7400:  9679 Terminated              ${INITDDIR}/httpd restart
[root@server custombuild]#
Please advice. Edit: However when I do "service httpd restart" after that, then it is no errors anymore. Hmm.
@smtalk, I am still working on all this. I am now on custombuild 2.0. I am running MySQL version 5.5.30. However in php-info page it say this:
Version mysqlnd 5.0.10 - 20111026 - $Id: e707c415db32080b3752b232487a435ee0372157 $
Should it not be a newer version, version 5.5.x? Is this wrong?
@smtalk, I still going over everything. I am not able to do this in custombuild:
./build libiconv
Why does it not work? I find it exist in this path: /usr/local/directadmin/custombuild/libiconv-1.14.tar.gz - also it says on the cb 2.0 faq that it is supported.
Edit: I found that it is changed, it should now be done like this:
./build iconv
Please change cb 2.0 faq at http://forum.directadmin.com/showthread.php?t=44743 it says:
1. What is custombuild?
Custombuild is a tool, which can install/update:
libiconv
I think it is confusing, better to change the faq to say iconv instead.
@smtak, Here is something: In custombuild 2.0, everytime I build php I get server load going up to 11.00 at the most! This happen only when I do ./build php n, when I build other applications this does not happen. This did never happen when I did ./build php n in custombuild 1.2
Is there something wrong in the ./build script for php in custombuild 2.0 that causes this? It seems so to me. My settings is php cli and mod_ruid2. Please let me know if you need more information.
This happen every time I build php, and only when it is php that I am building, and only happens in custombuild 2.0
Edit: However I can't be sure it is not my server. This is a 2GB Xen VPS from Linode. I was recently migrated to new hardware, therfor I can't be sure if the problem is with the build script or my server. However it is a powerful server with 8 cores, it is a: "Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz".
New question: When I run ./build php n in custombuild 2.0, I get this warning at the end:
libtool: install: warning: remember to run `libtool --finish /usr/local/directadmin/custombuild/php-5.4.14/libs'
I never had that warning in custombuild 1.2. Should I run `libtool --finish /usr/local/directadmin/custombuild/php-5.4.14/libs' or is it not needed? Custombuild take care of it, right?
DirectAdmin WebServices Installer
Written by Martynas Bendorius and DirectAdmin
Version: 2.0.0-RC2
To build everything run:
./build all
NOTE: Command all will compile everything as it is set
in the options.conf file, please take a look at
"./build options"!
Install/update server components:
./build apache
./build autoconf
./build automake
./build awstats
./build clamav
./build curl
./build dovecot
./build exim
./build freetype
./build iconv
./build icu
./build ioncube
./build libjpeg
./build libpng
Everything is fine in CustomBuild output (available commands).
It uses all of your cores to build PHP (to make the installation process faster).
https://bugs.php.net/bug.php?id=37432
http://forum.directadmin.com/showthread.php?t=42971
Thanks. I have completed the upgrade to cb 2.0 and mod_ruid2 on one of my servers now. It seems to work very well! Just a note to myself (and anybody that comes looking here), is to delete /var/log/suphp.log from etc/logrotate.d/apache (if you are converting from suphp to mod_ruid2 like I am. :)
