error_log last 50 lines:
Wed May 08 18:00:29 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed May 08 18:00:30 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:00:30 2013] [warn] RSA server certificate CommonName (CN) `
www.theocbase.me' does NOT match server name!?
[Wed May 08 18:00:30 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 configured -- resuming normal operations
[Wed May 08 18:00:30 2013] [notice] caught SIGTERM, shutting down
[Wed May 08 18:05:14 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:05:14 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:05:14 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:05:14 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed May 08 18:05:15 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:05:15 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:05:15 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:05:15 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 configured -- resuming normal operations
[Wed May 08 18:23:45 2013] [notice] caught SIGTERM, shutting down
[Wed May 08 18:33:58 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:33:58 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:33:58 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:33:58 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed May 08 18:33:59 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:33:59 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:33:59 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:33:59 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 configured -- resuming normal operations
[Wed May 08 18:44:21 2013] [notice] caught SIGTERM, shutting down
[Wed May 08 18:44:22 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:44:22 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:44:22 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:44:22 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed May 08 18:44:23 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:44:23 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:44:23 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:44:23 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 configured -- resuming normal operations
[Wed May 08 18:47:42 2013] [notice] caught SIGTERM, shutting down
[Wed May 08 18:47:43 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:47:43 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:47:43 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:47:43 2013] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed May 08 18:47:44 2013] [notice] SSL FIPS mode disabled
[Wed May 08 18:47:44 2013] [warn] RSA server certificate CommonName (CN) `
[Wed May 08 18:47:44 2013] [warn] Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed May 08 18:47:44 2013] [notice] Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips DAV/2 configured -- resuming normal operations
[Wed May 08 18:49:24 2013] [error] [client 173.214.255.79] File does not exist: /var/www/html/405.shtml
other log:
[Wed May 08 12:28:46 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 12:29:47 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 12:30:48 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 12:31:49 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 15:31:55 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 15:32:56 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 15:33:57 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 15:34:57 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 16:36:57 2013] [error] [client 176.31.242.6] client sent HTTP/1.1 request without hostname (see RFC2616 section 14.23): /w00tw00t.at.ISC.SANS.test0
[Wed May 08 18:35:04 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 18:36:05 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 18:37:06 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
[Wed May 08 18:38:07 2013] [error] [client 72.14.199.137] PHP Fatal error: Class 'JModuleHelper' not found in /home/theocbas/domains/theocbase.net/public_html/libraries/gantry/core/renderers/gantrymodulesrenderer.class.php on line 60
