nginx and phpmyadmin 404 Not Found error.
ozgurerdogan
I have nginx + php 5.3 but phpmyadmin link does not work as throws 404 not found error. But webmails are running fine. I think this is commonly seen but could not find a solution.
May you post your nginx logs? Are you trying /phpMyAdmin or /phpmyadmin? Do you have phpMyAdmin symlink in /var/www/html? Thank you.
can't find my post with the specific info now but other webapps fail with nginx. clicking webmail tab from DA fails too.
iirc with nginx the error log will show it looking for phpmyadmin/page/index.html or something like that. the /page directory (if that was the name used, may be wrong on that) doesn't exist.
Please update CustomBuild 2.0 to the latest version (RC4) and DA to the latest pre-release. That should fix your problems. If you do not have a way to download DA pre-release, you may try updating CB 2.0 only. After update just run "./build rewrite_confs" and let us know the result.
