Prelink failed with return value 134
ditto
For a few months, on all my three servers running CentOS 6.4 64bit, I get this email every night if I have been running ldconfig or done other upgrades, so this happens 2 or 3 times on each server every week. Here is the email:
Anacron job 'cron.daily' on server.hostname.com
/etc/cron.daily/prelink:
/etc/cron.daily/prelink: line 47: 17711 Aborted                 (core dumped) /usr/sbin/prelink -av $PRELINK_OPTS >> /var/log/prelink/prelink.log 2>&1
/var/log/prelink/prelink.log is 641 lines big. At the end of the log file I have this line:
Here is the complete prelink.log:
/usr/sbin/prelink -av -mR -q
/usr/sbin/prelink: /usr/sbin/makedumpfile: Could not parse `/usr/sbin/makedumpfile: /usr/local/lib/libz.so.1: no version information available (required by /usr/sbin/makedumpfile)'
/usr/sbin/prelink: /usr/local/lib/libpcre.so.0.0.1 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libpcre.so.1.2.0 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libz.so.1.2.3 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libiconv.so.2.5.1 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /etc/httpd/lib/libapr-1.so.0.4.6 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /etc/httpd/lib/libaprutil-1.so.0.5.2 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libexslt.so.0.8.17 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libxml2.so.2.9.1 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libcurl.so.4.3.0 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libltdl.so.7.3.0 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libxslt.so.1.1.28 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libpng12.so.0.50.0 is not present in any config file directories, nor was specified on command line
/usr/sbin/prelink: /usr/local/lib/libfreetype.so.6.10.1 is not present in any config file directories, nor was specified on command line
Laying out 66 libraries in virtual address space 0000003000000000-0000004000000000
Random base 0x0000003f61e00000
Assigned virtual address space slots for 64-bit x86-64 ELF libraries:
/lib64/ld-2.12.so                                            0000003ff4800000-0000003ff4a21188
/lib64/libaio.so.1.0.1                                       0000003b2d800000-0000003b2da00a80
/lib64/libc-2.12.so                                          0000003ff4c00000-0000003ff4f928a8
/lib64/libdl-2.12.so                                         0000003ff5000000-0000003ff5203100
/lib64/libpthread-2.12.so                                    0000003ff5400000-0000003ff561c3a0
/lib64/libm-2.12.so                                          0000003ff5800000-0000003ff5a830b8
/lib64/libselinux.so.1                                       000000301aa00000-000000301ac1e758
/lib64/librt-2.12.so                                         0000003ff5c00000-0000003ff5e07bb0
/lib64/libresolv-2.12.so                                     0000003ff7000000-0000003ff7219a88
/lib64/libcrypt-2.12.so                                      0000003ff7400000-0000003ff76361e0
/lib64/libfreebl3.so                                         0000003ff7800000-0000003ff7a616e0
/lib64/libbz2.so.1.0.4                                       0000003ff9400000-0000003ff9610050
/usr/lib64/libcrypto.so.10                                   0000003f61e00000-0000003f62199488
/lib64/libcom_err.so.2.1                                     0000003ff8000000-0000003ff82031b0
/lib64/libkeyutils.so.1.3                                    0000003ff9c00000-0000003ff9e02050
/lib64/libglib-2.0.so.0.2200.5                               0000003ff6400000-0000003ff66e4c10
/lib64/libexpat.so.1.5.2                                     0000003ffa000000-0000003ffa227dd0
/lib64/libk5crypto.so.3.1                                    000000301b600000-000000301b82b1a8
/lib64/libkrb5.so.3.3                                        000000301ba00000-000000301bce5aa0
/lib64/libgssapi_krb5.so.2.2                                 000000301be00000-000000301c0437e0
/lib64/libkrb5support.so.0.1                                 000000301b200000-000000301b40a450
/usr/lib64/libjpeg.so.62.0.0                                 0000003ffac00000-0000003ffae4fb60
/usr/lib/dovecot/libdovecot.so.0                             0000003f62200000-0000003f624ba900
/lib64/libattr.so.1.1.0                                      0000003ffa800000-0000003ffaa04160
/lib64/libcap.so.2.16                                        0000003ffc000000-0000003ffc203920
/lib64/libnspr4.so                                           0000003ffc400000-0000003ffc63cd40
/usr/lib64/libnssutil3.so                                    0000003ffd000000-0000003ffd22aa28
/lib64/libgcc_s-4.4.7-20120601.so.1                          0000003ff6800000-0000003ff6a15cf8
/lib64/libgobject-2.0.so.0.2200.5                            0000003ff8400000-0000003ff8644e28
/lib64/libgmodule-2.0.so.0.2200.5                            0000003ffb000000-0000003ffb2027f8
/lib64/libplds4.so                                           0000003ffbc00000-0000003ffbe03150
/usr/lib64/libnss3.so                                        0000003ffc800000-0000003ffcb3a748
/lib64/libplc4.so                                            0000003ffb800000-0000003ffba04178
/usr/lib64/libsmime3.so                                      0000003ffec00000-0000003ffee2bc60
/lib64/libuuid.so.1.3.0                                      00000038d3400000-00000038d3603728
/usr/lib64/libtiff.so.3                                      0000003f61e00000-0000003f62063928
/usr/lib64/libssl3.so                                        0000003f62200000-0000003f62435ff0
/lib64/libpopt.so.0.0.0                                      0000003ff7000000-0000003ff7208650
/usr/lib64/libxcb.so.1.1.0                                   0000003ffe000000-0000003ffe21d668
/usr/lib64/libstdc++.so.6.0.13                               0000003ff6c00000-0000003ff6f051b8
/usr/lib64/libXau.so.6.0.0                                   0000003ffd800000-0000003ffda02300
/lib64/libtinfo.so.5.7                                       0000003ff8800000-0000003ff8a21000
/usr/lib64/libfontconfig.so.1                                0000003f62600000-0000003f628359e8
/lib64/libblkid.so.1.1.0                                     00000038d3800000-00000038d3a20be8
/usr/lib64/libisc.so.83                                      0000003f62200000-0000003f62456990
/lib64/libgpg-error.so.0.5.0                                 0000003ffb400000-0000003ffb603058
/usr/lib64/libX11.so.6.3.0                                   0000003ffd400000-0000003ffd73cd78
/usr/lib64/libdns.so.81                                      0000003f62600000-0000003f62998788
/usr/lib64/libssl.so.10                                      0000003f62600000-0000003f6285c870
/lib64/libgcrypt.so.11.5.3                                   0000003ffcc00000-0000003ffce74a40
/lib64/libpam.so.0.82.2                                      0000003ff6c00000-0000003ff6e0d220
/lib64/libsepol.so.1                                         0000003ff5c00000-0000003ff5e3ca80
/lib64/libaudit.so.1.0.0                                     0000003ff5800000-0000003ff5a1b230
/lib64/libnsl-2.12.so                                        0000003ffdc00000-0000003ffde18ab0
/usr/lib64/libgnutls.so.26                                   0000003f62a00000-0000003f62ca2bc8
/usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so                    0000003f61e00000-0000003f620e5f38
/lib64/libudev.so.0.5.1                                      0000003ff6400000-0000003ff660d860
/lib64/libdevmapper.so.1.02                                  000000301ae00000-000000301b039d50
/usr/lib64/libXext.so.6.4.0                                  0000003000400000-0000003000612d08
/lib64/libacl.so.1.1.0                                       0000003ff6c00000-0000003ff6e07250
/lib64/libdb-4.7.so                                          0000003ff7c00000-0000003ff7f738a0
/usr/lib64/libtasn1.so.3.1.6                                 0000003000c00000-0000003000e0fd48
/lib64/libgio-2.0.so.0.2200.5                                000000301ae00000-000000301b0aa4f0
/lib64/libdbus-1.so.3.4.0                                    0000003ff7c00000-0000003ff7e40948
/usr/lib64/libuser.so.1.2.2                                  000000301ae00000-000000301b018ab0
/lib64/libpam_misc.so.0.82.0                                 0000003ff5400000-0000003ff5603110
/lib64/libncurses.so.5.7                                     0000003fff800000-0000003fffa21ce8
/usr/lib64/librtmp.so.0                                      0000003f62e00000-0000003f63017d98
/lib64/libidn.so.11.6.1                                      0000003ff6800000-0000003ff6a31f48
/usr/lib64/libelf-0.152.so                                   0000003ff7800000-0000003ff7a14140
/usr/lib/dovecot/libdovecot-storage.so.0                     0000003f61e00000-0000003f6210fe38
/usr/lib64/libdbus-glib-1.so.2.1.0                           0000003ff6800000-0000003ff6a22588
/usr/lib64/libpolkit-gobject-1.so.0.0.0                      000000301b600000-000000301b822978
/usr/lib64/libeggdbus-1.so.0.0.0                             000000301b200000-000000301b447cd0
/usr/lib64/libImlib2.so.1                                    0000003f61e00000-0000003f6207bb60
/usr/lib64/liblzma.so.0.0.0                                  0000003ff8400000-0000003ff8620790
/usr/lib64/liblcms.so.1.0.19                                 0000003003800000-0000003003a388c0
/usr/lib64/libopenjpeg.so.2.1.3.0                            0000003003c00000-0000003003e1d980
/lib64/libgthread-2.0.so.0.2200.5                            0000003000000000-0000003000203c98
/usr/lib64/libisccfg.so.82                                   0000003f62a00000-0000003f62c21e08
/usr/lib64/libltdl.so.7.2.1                                  0000003e26400000-0000003e266088a8
/usr/lib64/libgdk_pixbuf-2.0.so.0                            0000003f61e00000-0000003f6201ec18
/usr/lib64/libisccc.so.80                                    0000003f62e00000-0000003f63007588
/usr/lib64/libXfixes.so.3.1.0                                0000003003400000-0000003003605318
/usr/lib64/libpoppler.so.5                                   0000003f61e00000-0000003f621da570
/usr/lib64/libXrender.so.1.3.0                               0000003005400000-0000003005609488
/usr/lib64/libspeex.so.1.5.0                                 0000003006c00000-0000003006e18d48
/usr/lib64/libopencore-amrwb.so.0.0.2                        0000003007000000-0000003007215728
/usr/lib64/liborc-0.4.so.0.11.0                              0000003004000000-000000300427fbc0
/usr/lib64/libcairo.so.2                                     0000003f63200000-0000003f63478b78
/usr/lib64/libmp3lame.so.0.0.0                               0000003005800000-0000003005a76a80
/usr/lib64/libdirac_encoder.so.0.1.0                         0000003004400000-000000300468e050
/usr/lib64/libx264.so.107                                    0000003005c00000-0000003005ea3ce0
/usr/lib64/libpangoft2-1.0.so.0                              0000003f63600000-0000003f63829f28
/usr/lib64/libschroedinger-1.0.so.0.10.0                     0000003007400000-00000030076bded0
/usr/lib64/libbind9.so.80                                    0000003f63200000-0000003f6340bbb0
/lib64/libasound.so.2.0.0                                    0000003ffe400000-0000003ffe6ea428
/lib64/libext2fs.so.2.4                                      0000003ff5c00000-0000003ff5e30e40
/usr/lib64/libclamav.so.6                                    0000003f61e00000-0000003f6297fe80
/usr/lib64/libfaac.so.0.0.0                                  0000003004800000-0000003004a11c38
/usr/lib64/libpixman-1.so.0.26.2                             00000032f3400000-00000032f3687b40
/usr/lib64/libopencore-amrnb.so.0.0.2                        0000003007c00000-0000003007e2ed30
/usr/lib64/libpango-1.0.so.0.2800.1                          0000003006800000-0000003006a4ac60
/usr/lib64/libogg.so.0.6.0                                   0000003fffc00000-0000003fffe05330
/usr/lib64/libreport.so.0.0.1                                0000003ff7400000-0000003ff7615c60
/usr/lib64/libsasl2.so.2.0.23                                0000003001c00000-0000003001e197b0
/lib64/libe2p.so.2.3                                         0000003ff6000000-0000003ff6206870
/lib64/libutil-2.12.so                                       0000003ff5c00000-0000003ff5e02100
/usr/lib64/libdw.so.1                                        0000003f61e00000-0000003f62034f60
/lib64/libreadline.so.6.0                                    0000003ff7400000-0000003ff7642a08
/usr/lib64/libusb-1.0.so.0.1.0                               0000003ff7400000-0000003ff760e640
/usr/lib64/libpangocairo-1.0.so.0                            0000003f63a00000-0000003f63c0b8f0
/usr/lib64/libavutil.so.50.15.1                              0000003ff7000000-0000003ff7211908
/usr/lib64/libtheoradec.so.1.1.3                             0000003ff8400000-0000003ff860ec68
/usr/lib64/libtheoraenc.so.1.1.2                             0000003ffaa00000-0000003ffac2c910
/usr/lib64/libswscale.so.0.11.0                              0000003ff8c00000-0000003ff8e32bb8
/usr/lib64/libraw1394.so.11.0.1                              0000003ff6000000-0000003ff620d698
/usr/lib64/libOpenIPMIposix.so.0.0.1                         0000003ff7400000-0000003ff7604ea0
/usr/lib64/libva.so.1.0.6                                    0000003ff6400000-0000003ff665e870
/lib64/libdevmapper-event.so.1.02                            000000301b200000-000000301b404cb8
/lib64/liblber-2.4.so.2                                      0000003f63e00000-0000003f6400e528
/lib64/libldap-2.4.so.2                                      0000003f64200000-0000003f6444c418
/usr/lib64/liblwres.so.80                                    0000003f63600000-0000003f638116c8
/usr/lib64/libpostproc.so.51.2.0                             0000003ff8800000-0000003ff8a0dcf0
/usr/lib64/libavformat.so.52                                 0000003f61e00000-0000003f620c8a08
/usr/lib64/libOpenIPMIutils.so.0.0.1                         0000003ff6000000-0000003ff6207438
/usr/lib64/libbtparser.so.2.2.2                              0000003ff7800000-0000003ff7a106b8
/usr/lib64/libavdevice.so.52                                 0000003f62200000-0000003f6240ac28
/usr/lib64/libavfilter.so.1                                  0000003f62600000-0000003f6280c6b0
/usr/lib64/libdc1394.so.22.1.4                               0000003ff9000000-0000003ff92745e8
/usr/lib64/libgsm.so.1.0.12                                  0000003ff7c00000-0000003ff7e0a450
/usr/lib64/libavcodec.so.52                                  0000003f63200000-0000003f63e456c8
/usr/lib64/libgdbm.so.2.0.0                                  0000003ff6800000-0000003ff6a05dc0
/usr/lib64/libOpenIPMI.so.0                                  0000003f62200000-0000003f62507dd8
/usr/lib64/libmpg123.so.0                                    0000003f64600000-0000003f64859788
/lib64/libmultipath.so                                       0000003ff5800000-0000003ff5a41b58
/usr/lib64/libatk-1.0.so.0.2809.1                            000000300cc00000-000000300ce1f8a0
/usr/lib64/librpm.so.1                                       0000003f61e00000-0000003f6206a348
/usr/lib64/libcroco-0.6.so.3                                 0000003f62200000-0000003f6243c520
/usr/lib64/libXcursor.so.1.0.2                               0000003009c00000-0000003009e09540
/usr/lib64/libXcomposite.so.1.0.0                            000000300c800000-000000300ca01eb8
/usr/lib64/libabrt_web.so.0                                  0000003f62200000-0000003f62403830
/usr/lib64/libproxy.so.0.0.0                                 0000003ff9400000-0000003ff9606eb0
/usr/lib64/libxmlrpc_client.so.3                             0000003f63200000-0000003f6340a588
/usr/lib64/libXi.so.6.1.0                                    000000300c000000-000000300c20e500
/usr/lib64/libgtk-x11-2.0.so.0                               0000003f64a00000-0000003f65064df0
/usr/lib64/libxmlrpc.so.3                                    0000003f63600000-0000003f638137d0
/lib64/libncursesw.so.5.7                                    0000003002000000-000000300222ec90
/usr/lib64/libgdk-x11-2.0.so.0                               0000003f65200000-0000003f654bafe8
/usr/lib64/libfontenc.so.1                                   0000003f61e00000-0000003f62006920
/usr/lib64/perl5/CORE/libperl.so                             0000003be4a00000-0000003be4d6a6a8
/usr/lib64/liblua-5.1.so                                     0000003ff8c00000-0000003ff8e2c700
/usr/lib/dovecot/libdovecot-login.so.0                       0000003f62a00000-0000003f62c18ff8
/usr/lib64/libgpm.so.2.1.0                                   0000003004c00000-0000003004e058d8
/usr/lib64/libXrandr.so.2.2.0                                000000300a400000-000000300a608ae8
/usr/lib64/libtar.so.1.2.11                                  0000003ffa000000-0000003ffa20a6e0
/usr/lib64/libXdamage.so.1.1.0                               000000300ac00000-000000300ae01b68
/usr/lib64/libxmlrpc_util.so.3.16                            0000003ff8800000-0000003ff8a03a48
/usr/lib64/librpmio.so.1                                     0000003f62200000-0000003f6242ed20
/usr/lib64/libXinerama.so.1.0.0                              000000300d000000-000000300d201ac8
/usr/lib64/libUsageEnvironment.so.%{date}                    000000300e400000-000000300e6024c0
/usr/lib64/libnetsnmp.so.20                                  0000003f62600000-0000003f628d8200
/usr/lib64/libmad.so.0.2.1                                   0000003010400000-000000301061df70
/usr/lib64/libgsf-1.so.114                                   0000003f62a00000-0000003f62c3fab0
/usr/lib/dovecot/libdovecot-lda.so.0                         0000003f62600000-0000003f6280bc98
/usr/lib64/libBasicUsageEnvironment.so.%{date}               000000300f400000-000000300f609be0
/usr/lib64/libhal.so.1.0.0                                   0000003ff5000000-0000003ff520fc58
/usr/lib64/libICE.so.6.3.0                                   0000003012000000-000000301221b4c0
/usr/lib64/libxvidcore.so.4.2                                0000003011400000-000000301170edd0
/usr/lib64/liba52.so.0.0.0                                   000000300a000000-000000300a20c770
/usr/lib64/libpng12.so.0                                     0000003f62e00000-0000003f63025738
/usr/lib64/libcupsimage.so.2                                 0000003f62200000-0000003f624188c0
/usr/lib64/libliveMedia.so.%{date}                           000000300d800000-000000300dae7808
/usr/lib64/libtheora.so.0.3.9                                0000003010800000-0000003010a338e0
/usr/lib64/libgconf-2.so.4.1.5                               0000003ff7400000-0000003ff763ed50
/usr/lib64/libgmp.so.3.5.0                                   0000003ff5400000-0000003ff565af00
/usr/lib64/libsmbclient.so.0                                 0000003f65600000-0000003f65dc2288
/usr/lib64/libSDL-1.2.so.0.11.3                              0000003011000000-000000301129d698
/usr/lib64/libpangox-1.0.so.0.2800.1                         0000003ff6000000-0000003ff620bf00
/usr/lib64/libcdda_interface.so.0.10.2                       000000300fc00000-000000300fe16160
/usr/lib64/libopcodes-2.20.51.0.2-5.36.el6.so                0000003f62200000-0000003f624f0ea0
/usr/lib64/libtdb.so.1.2.10                                  000000300f000000-000000300f210890
/lib64/libfipscheck.so.1.1.0                                 0000003ff5400000-0000003ff56020c0
/usr/lib64/liblzo2.so.2.0.0                                  0000003013400000-0000003013620448
/usr/lib64/libavahi-client.so.3.2.5                          0000003ff8800000-0000003ff8a0fa80
/usr/lib64/libwbclient.so.0                                  0000003012c00000-0000003012e0dea0
/usr/lib64/librsvg-2.so.2                                    0000003f63e00000-0000003f64036b00
/usr/lib64/libavahi-common.so.3.5.1                          0000003ff8400000-0000003ff860b730
/usr/lib64/libdv.so.4.0.3                                    000000300e800000-000000300ea2bbc0
/lib64/libdmraid.so.1.0.0.rc16                               000000301b600000-000000301b835000
/lib64/libparted-2.1.so.0.0.0                                000000301b200000-000000301b47faa0
/usr/lib64/libgroupsock.so.%{date}                           000000300dc00000-000000300de19790
/usr/lib64/libfribidi.so.0.0.0                               000000300c400000-000000300c60f9d8
/usr/lib64/libgif.so.4.1.6                                   00000038d8000000-00000038d8208890
/usr/lib64/libcups.so.2                                      0000003f62e00000-0000003f6304ea68
/usr/lib64/libmng.so.1                                       0000003f65e00000-0000003f66072c98
/usr/lib64/libXft.so.2                                       0000003f61e00000-0000003f62014860
/usr/lib64/libcdda_paranoia.so.0.10.2                        0000003011800000-0000003011a09fd8
/usr/lib64/libfreetype.so.6.3.22                             0000003ff8000000-0000003ff829c6b0
/usr/lib64/libSM.so.6.0.1                                    00000038d8400000-00000038d86073b8
/usr/lib64/libenca.so.0.5.1                                  000000300a800000-000000300aa31d80
/usr/lib64/libdca.so.0.0.0                                   000000300f800000-000000300fa28350
/usr/lib64/libpcreposix.so.0                                 0000003f61e00000-0000003f62001518
/usr/lib64/libpangoxft-1.0.so.0                              0000003f62200000-0000003f62407658
/usr/lib64/libungif.so.4.1.6                                 00000038d7800000-00000038d7a00758
/usr/lib64/libORBit-2.so.0.1.0                               0000003ff6c00000-0000003ff6e6fb88
/usr/lib64/libdirac_decoder.so.0.1.0                         0000003009800000-0000003009a66e10
/usr/lib64/libmpcdec.so.5.0.2                                000000300e000000-000000300e20c6f0
/lib64/libmpathpersist.so.0                                  000000301b200000-000000301b407708
/usr/lib64/libxml2.so.2                                      0000003f64200000-0000003f64551eb8
/usr/lib64/libmagic.so.1                                     0000003f62600000-0000003f6281df08
/usr/lib64/libtalloc.so.2.0.7                                000000300ec00000-000000300ee09a20
/usr/lib64/librpmbuild.so.1                                  0000003f62a00000-0000003f62c2bbd0
/usr/lib64/libOpenIPMIglib.so.0.0.1                          0000003ff8000000-0000003ff8202e10
/usr/lib64/libssh2.so.1                                      0000003f63200000-0000003f63427100
/usr/lib64/libsndfile.so.1.0.20                              0000003002c00000-0000003002e63a10
/lib64/libwrap.so.0.7.6                                      0000003014c00000-0000003014e0a0a8
/usr/lib64/libcaca.so.0                                      0000003f66200000-0000003f664d1cd8
/usr/lib64/libfprint.so.0                                    0000003f62600000-0000003f656e14b8
/usr/lib64/libpcap.so.1.0.0                                  0000003ff5400000-0000003ff5636da0
/usr/lib64/libXss.so.1.0.0                                   0000003018800000-0000003018a02348
/usr/lib64/libgc.so.1.0.3                                    0000003ff5c00000-0000003ff5f0a790
/usr/lib64/libgd.so.2                                        0000003f61e00000-0000003f62046208
/usr/lib64/libpolkit-backend-1.so.0.0.0                      000000301ba00000-000000301bc40fe8
/usr/lib64/libabrt.so.0.0.1                                  0000003ff8000000-0000003ff8204bd8
/usr/lib64/libaa.so.1.0.4                                    0000003008400000-000000300861dd18
/usr/lib64/libXfont.so.1                                     0000003f62200000-0000003f62434970
/lib64/libpci.so.3.1.10                                      0000003ff5800000-0000003ff5a0b760
/usr/lib64/libslang.so.2.2.1                                 0000003009400000-0000003009769ef8
/usr/lib64/libvdpau.so.1.0.0                                 0000003014000000-0000003014201b70
/usr/lib64/libdrm.so.2.4.0                                   0000003010000000-000000301020ad50
/usr/lib64/libesd.so.0.2.39                                  0000003015000000-000000301520aef8
/usr/lib64/libFLAC.so.8.2.0                                  0000003002800000-0000003002a39ca8
/usr/lib64/libOpenIPMIcmdlang.so.0                           0000003f62a00000-0000003f62c41e48
/usr/lib64/libgs.so.8                                        0000003f63600000-0000003f6411da18
/usr/lib64/libaudiofile.so.0.0.2                             0000003003000000-0000003003228470
/usr/lib64/libXv.so.1.0.0                                    0000003013800000-0000003013a04528
/usr/lib64/libasyncns.so.0.3.1                               0000003015800000-0000003015a04618
/lib64/libproc-3.2.8.so                                      0000003ff5400000-0000003ff5622f98
/usr/lib64/libX11-xcb.so.1.0.0                               0000003015400000-00000030156008b0
/usr/lib64/libglut.so.3.9.0                                  0000003020600000-0000003020846b28
/usr/lib64/libutempter.so.1.1.5                              0000003ff5400000-0000003ff56012a0
/usr/lib64/libglapi.so.0.0.0                                 0000003020a00000-0000003020c50c48
/usr/lib64/libjasper.so.1.0.0                                0000003ffb800000-0000003ffba58de8
/usr/lib64/libxcb-glx.so.0.0.0                               0000003017400000-0000003017615f00
/usr/lib64/libGL.so.1.2.0                                    0000003021600000-0000003021882430
/usr/lib64/libXpm.so.4.11.0                                  0000003ff6000000-0000003ff6210af8
/usr/lib64/libXvMC.so.1.0.0                                  0000003014400000-0000003014602be8
/usr/sbin/r1soft/bin/2-6/libtbb.so.2                         000000301ac00000-000000301ad65c48
/lib64/libcryptsetup.so.1.1.0                                000000301b200000-000000301b4168c0
/usr/lib64/libvorbis.so.0.4.3                                0000003001000000-000000300122bf68
/usr/lib64/libGLU.so.1.3.1                                   0000003021200000-000000302147f2d0
/usr/lib64/libXxf86vm.so.1.0.0                               0000003014800000-0000003014a04708
/usr/lib64/libXxf86dga.so.1.0.0                              0000003016400000-0000003016605748
/usr/lib64/libvga.so.1.9.25                                  0000003008800000-0000003008a8dee8
/usr/lib64/libIPMIlanserv.so.0                               0000003f62200000-0000003f6240dbe0
/usr/lib64/libpython2.6.so.1.0                               0000003ff6800000-0000003ff6ba55a0
/usr/lib64/libtwolame.so.0.0.0                               0000003ff6400000-0000003ff66225a8
/usr/lib64/libpulsecommon-0.9.21.so                          00000038d8c00000-00000038d8e4e9d8
/usr/lib64/libpulse.so.0.12.2                                00000038d8800000-00000038d8a41838
/usr/sbin/r1soft/bin/2-6/libtbbmalloc.so.2                   000000301aa00000-000000301ab40e88
/lib64/libss.so.2.0                                          0000003ff6400000-0000003ff6606380
/lib64/libmount.so.1.1.0                                     00000038d3c00000-00000038d3e0f988
/usr/lib64/libvorbisenc.so.2.0.6                             0000003001400000-00000030017d96a0
/usr/lib64/libOpenIPMIui.so.1.0.1                            0000003ff5400000-0000003ff562adb0
/usr/lib64/libXvMCW.so.1.0.0                                 0000003017800000-0000003017a039a0
/usr/lib64/libXtst.so.6.1.0                                  0000003018400000-0000003018605478
/usr/lib64/libartsc.so.0.0.0                                 0000003016000000-00000030162058a0
/usr/lib64/libpanelw.so.5.7                                  0000003ff6000000-0000003ff6202670
/usr/lib64/libsmbios_c.so.2.2.1                              0000003ff5000000-0000003ff5239ea8
/usr/lib64/libmcop.so.1.0.0                                  0000003ff7000000-0000003ff72d0818
/usr/lib64/libsmbios.so.2.1.0                                0000003ff5000000-0000003ff529a8e0
/usr/lib64/libsoundserver_idl.so.1.0.0                       0000003ff6000000-0000003ff62abb80
/usr/lib64/libppl.so.7.1.0                                   0000003ff5000000-0000003ff52b65c8
/lib64/libply.so.2.0.0                                       0000003ff6000000-0000003ff6215b60
/usr/lib64/libruby.so.1.8.7                                  0000003ff6000000-0000003ff6304f08
/usr/lib64/libmenuw.so.5.7                                   0000003ff6400000-0000003ff6606f40
/usr/lib64/libabrt_dbus.so.0.0.1                             0000003ff5000000-0000003ff5202340
/lib64/libip6tc.so.0.0.0-1.4.7                               0000003ff5c00000-0000003ff5e06630
/usr/lib64/libpth.so.20.0.27                                 0000003ff5400000-0000003ff5614fb8
/usr/lib64/libpakchois.so.0.1.0                              0000003ffbc00000-0000003ffbe05370
/lib64/libnl.so.1.1                                          0000003ff5c00000-0000003ff5e51f88
/usr/lib64/libvorbisfile.so.3.3.2                            0000003ff8000000-0000003ff8206ff0
/usr/lib64/libnewt.so.0.52.11                                0000003ff5400000-0000003ff56142c8
/lib64/libip4tc.so.0.0.0-1.4.7                               0000003ff5c00000-0000003ff5e05f08
/usr/lib64/libkmedia2_idl.so.1.0.0                           0000003ff7c00000-0000003ff7e6cea0
/usr/lib64/libmpfr.so.1.2.0                                  0000003ff5800000-0000003ff5a4d560
/lib64/libcgroup.so.1.0.37                                   0000003ff6000000-0000003ff646bcb0
/usr/lib64/libostyle.so.0.0.1                                0000003ff5c00000-0000003ff606d5c0
/usr/lib64/libosp.so.5.0.0                                   0000003ff5000000-0000003ff53f2a40
/usr/lib64/libformw.so.5.7                                   0000003ff6800000-0000003ff6a0ff88
/usr/lib64/libartsflow.so.1.0.0                              0000003ff7800000-0000003ff7ba6d90
/usr/lib64/libtic.so.5.7                                     0000003ff5000000-0000003ff5212888
/usr/lib64/libcrack.so.2.8.1                                 0000003ff5000000-0000003ff520ca20
/usr/lib64/libsqlite3.so.0.8.6                               0000003ff5c00000-0000003ff5e8e590
/usr/lib64/libcloog.so.0.0.0                                 0000003ff6000000-0000003ff6221958
/lib64/libiw.so.29                                           0000003ff5000000-0000003ff52077b0
/usr/lib64/libfaad.so.2.0.0                                  0000003ff5000000-0000003ff523e7a8
/usr/lib64/libhunspell-1.2.so.0.0.0                          0000003ff5400000-0000003ff5640a98
/lib64/libxtables.so.4.0.0-1.4.7                             0000003ff5400000-0000003ff5607b80
/usr/lib64/libartsflow_idl.so.1.0.0                          0000003ff7400000-0000003ff772edc0
/usr/lib64/libmcop_mt.so.1.0.0                               0000003ff8400000-0000003ff86046f0
/usr/lib64/libva-x11.so.1.0.6                                0000003ff5800000-0000003ff5a06ce8
/usr/lib64/libhal-storage.so.1.0.0                           0000003ff5800000-0000003ff5a09bd0
/usr/lib64/libck-connector.so.0.0.0                          0000003ff5000000-0000003ff52026b8
/lib64/libauparse.so.0.0.0                                   0000003ff5000000-0000003ff520e2b0
/usr/lib64/libppl_c.so.2.1.0                                 0000003ff7000000-0000003ff75663e8
/usr/lib64/libasm-0.152.so                                   0000003ff5400000-0000003ff5606870
/usr/lib64/librarian.so.0.0.0                                0000003ff5000000-0000003ff521cae8
/usr/lib64/liboil-0.3.so.0.3.0                               0000003ff5000000-0000003ff52904d0
/usr/lib64/liborc-test-0.4.so.0.11.0                         0000003ff5000000-0000003ff5205e98
/usr/lib64/libospgrove.so.0.0.1                              0000003ff6200000-0000003ff648c680
/lib64/libply-splash-core.so.2.0.0                           0000003ff6400000-0000003ff6610b10
/usr/lib64/libgmpxx.so.4.1.0                                 0000003ff5c00000-0000003ff5e03458
/usr/lib64/libcppunit-1.12.so.1.0.0                          0000003ff5400000-0000003ff563fa78
/usr/lib64/libnuma.so.1                                      0000003ff5000000-0000003ff52089c0
/usr/lib64/libogrove.so.0.0.1                                0000003ff7000000-0000003ff72105e8
Assigned virtual address space slots for 32-bit i386 ELF libraries:
/lib/ld-2.12.so                                              008f7000-009168f8
/lib/libc-2.12.so                                            00919000-00aaf988
/usr/sbin/prelink: Could not prelink /usr/lib64/libcrypto.so.10 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libssl.so.10 because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/httpd because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libisc.so.83 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libfontconfig.so.1 because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-query because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libmagic.so.1 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib/dovecot/libdovecot.so.0 because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib/dovecot/libdovecot-storage.so.0 because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib/dovecot/libdovecot-lda.so.0 because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/dovecot-lda because its dependency /usr/lib/dovecot/libdovecot-lda.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libfontenc.so.1 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fonttosfnt because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libssl3.so because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /lib64/liblber-2.4.so.2 because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /lib64/libldap-2.4.so.2 because its dependency /lib64/liblber-2.4.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libsmbclient.so.0 because its dependency /lib64/libldap-2.4.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libmng.so.1 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libmpg123.so.0 because its dependency /usr/local/lib/libltdl.so.7 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgnutls.so.26 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/librtmp.so.0 because its dependency /usr/lib64/libgnutls.so.26 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libcaca.so.0 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libcairo.so.2 because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpangoft2-1.0.so.0 because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpangocairo-1.0.so.0 because its dependency /usr/lib64/libcairo.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgdk_pixbuf-2.0.so.0 because its dependency /usr/local/lib/libpng12.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgdk-x11-2.0.so.0 because its dependency /usr/lib64/libpangocairo-1.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgtk-x11-2.0.so.0 because its dependency /usr/lib64/libgdk-x11-2.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/mplayer because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libOpenIPMI.so.0 because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/solterm because its dependency /usr/lib64/libOpenIPMI.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/config because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-match because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/htcacheclean because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/imap-urlauth because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/dns-client because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libtiff.so.3 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffset because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/gpg2keys_ldap because its dependency /lib64/libldap-2.4.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-scan because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpoppler.so.5 because its dependency /usr/local/lib/libpng12.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/script because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/fcgistarter because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/btoa because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/imap because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/modutil because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ftpwho because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /bin/grep because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpng12.so.0 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/strings because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/c++filt because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/signver because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/lmtp because its dependency /usr/lib/dovecot/libdovecot-lda.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libcroco-0.6.so.3 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/csslint-0.6 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libopcodes-2.20.51.0.2-5.36.el6.so because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/objdump because its dependency /usr/lib64/libopcodes-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libdns.so.81 because its dependency /usr/lib64/libisc.so.83 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/ddns-confgen because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/liblwres.so.80 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libisccc.so.80 because its dependency /usr/lib64/libisc.so.83 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libisccfg.so.82 because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libbind9.so.80 because its dependency /usr/lib64/libisccfg.so.82 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/host because its dependency /usr/lib64/liblwres.so.80 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdftohtml because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/logresolve because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/doveadm-server because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libclamav.so.6 because its dependency /usr/local/lib/libltdl.so.7 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/clambc because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiff2bw because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/clamd because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffcmp because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffinfo because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/strsclnt because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/gdbhelper because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/gpg2keys_hkp because its dependency /usr/local/lib/libcurl.so.4 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/dig because its dependency /usr/lib64/liblwres.so.80 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/atob because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/htdigest because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib/dovecot/libdovecot-login.so.0 because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/doveconf because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/rgb2ycbcr because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/sigtool because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-dsfromkey because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ld because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/imap-urlauth-worker because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/proftpd because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/librpmio.so.1 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/librpm.so.1 because its dependency /usr/lib64/librpmio.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/librpmbuild.so.1 because its dependency /usr/lib64/librpm.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /bin/rpm because its dependency /usr/lib64/librpmbuild.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/ftpshut because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ras2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pk12util because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ranlib because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgsf-1.so.114 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/librsvg-2.so.2 because its dependency /usr/lib64/libgsf-1.so.114 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libxml2.so.2 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/rsvg-view because its dependency /usr/lib64/libgtk-x11-2.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/maildirlock because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fax2ps because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/exim because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/htpasswd because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/crlutil because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgd.so.2 because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/rndc-confgen because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/rawlog because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gtk-query-immodules-2.0-64 because its dependency /usr/lib64/libgtk-x11-2.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /sbin/mkfs.cramfs because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gif2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fax2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libXft.so.2 because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpangoxft-1.0.so.0 because its dependency /usr/lib64/libpangoft2-1.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdfimages because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gpg2 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ftpdctl because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/clamconf because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffcrop because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libIPMIlanserv.so.0 because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ipmilan because its dependency /usr/lib64/libIPMIlanserv.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fipscheck because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-list because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/ftpscrub because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fipshmac because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libXfont.so.1 because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/bdftopcf because its dependency /usr/lib64/libXfont.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/isc-hmac-fixup because its dependency /usr/lib64/libisc.so.83 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/bmp2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /sbin/fsck.cramfs because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libssh2.so.1 because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/xsltproc because its dependency /usr/local/lib/libxslt.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libImlib2.so.1 because its dependency /usr/local/lib/libfreetype.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_grab because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/anvil because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libcups.so.2 because its dependency /usr/lib64/libgnutls.so.26 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libcupsimage.so.2 because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libgs.so.8 because its dependency /usr/lib64/libcairo.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/log because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/rpm2cpio because its dependency /usr/lib64/librpm.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gconftool-2 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-cat because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/httxt2dbm because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libdw.so.1 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/eu-findtextrel because its dependency /usr/lib64/libdw.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/pp because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/ipc because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gdk-pixbuf-query-loaders-64 because its dependency /usr/lib64/libgdk_pixbuf-2.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/selfserv because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/rndc because its dependency /usr/lib64/libisccfg.so.82 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pal2rgb because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/pop3 because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/pop3-login because its dependency /usr/lib/dovecot/libdovecot-login.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/tcpdump because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdftoppm because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/less because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/rotatelogs because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/efibootmgr because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libpcreposix.so.0 because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pcregrep because its dependency /usr/lib64/libpcreposix.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/raw2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/ssl-params because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/libtar because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiff2rgba because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ppm2tiff because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/abrt-action-save-package-data because its dependency /usr/lib64/librpm.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_poly because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pango-querymodules-64 because its dependency /usr/lib64/libpangoxft-1.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ftptop because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdftotext because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libavcodec.so.52 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libavformat.so.52 because its dependency /usr/lib64/libavcodec.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libavdevice.so.52 because its dependency /usr/lib64/libavformat.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libavfilter.so.1 because its dependency /usr/lib64/libavcodec.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ffserver because its dependency /usr/lib64/libavdevice.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/openipmicmd because its dependency /usr/lib64/libOpenIPMI.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gs because its dependency /usr/lib64/libgs.so.8 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_show because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/checkgid because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/indexer because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pango-view because its dependency /usr/lib64/libpangoft2-1.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/eu-addr2line because its dependency /usr/lib64/libdw.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/named-journalprint because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ffprobe because its dependency /usr/lib64/libavdevice.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gpgsplit because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/htdbm because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/readelf because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libnetsnmp.so.20 because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ipmi_ui because its dependency /usr/lib64/libOpenIPMI.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/script-login because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/cmsutil because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffmedian because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/htdbm because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /bin/mailx because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libxmlrpc.so.3 because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ssltap because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/named-checkzone because its dependency /usr/lib64/libisccfg.so.82 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ftpcount because its dependency /usr/local/lib/libiconv.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/wget because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/vfychain because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /sbin/install-info because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gtk-update-icon-cache because its dependency /usr/lib64/libgdk_pixbuf-2.0.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ck-history because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libxmlrpc_client.so.3 because its dependency /usr/lib64/libxmlrpc.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libabrt_web.so.0 because its dependency /usr/local/lib/libcurl.so.4 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/reporter-rhtsupport because its dependency /usr/lib64/libabrt_web.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib/cups/filter/pdftoraster because its dependency /usr/lib64/libcupsimage.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-signzone because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/xmlcatalog because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/spamc because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/vfyserv because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/imap-urlauth-login because its dependency /usr/lib/dovecot/libdovecot-login.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/imap-login because its dependency /usr/lib/dovecot/libdovecot-login.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiff2pdf because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/thumbnail because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/ab because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffdither because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/strip because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/objcopy because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-keygen because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/abrt-dedup-client because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /sbin/kexec because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/troff because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffdump because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffsplit because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_conv because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdfinfo because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dovecot because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-revoke because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/size because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-keyfromlabel because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/symkeyutil because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/curl because its dependency /usr/local/lib/libcurl.so.4 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/fc-cache because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_colorspace because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/w3m/inflate because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/xmllint because its dependency /usr/local/lib/libxml2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/dict because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/indexer-worker because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/derdump because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdftops because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libfprint.so.0 because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/fprintd because its dependency /usr/lib64/libfprint.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/checkpassword-reply because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/nss/unsupported-tools/tstclnt because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiff2ps because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_bumpmap because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/nm because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/htpasswd because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/arpaname because its dependency /usr/lib64/libisc.so.83 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/signtool because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_view because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/tiffcp because its dependency /usr/lib64/libtiff.so.3 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/gpg2keys_curl because its dependency /usr/local/lib/libcurl.so.4 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/nsec3hash because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ffmpeg because its dependency /usr/lib64/libavdevice.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/director because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/rsvg-convert because its dependency /usr/lib64/librsvg-2.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/logresolve because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ffplay because its dependency /usr/lib64/libavdevice.so.52 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/listview because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/freshclam because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/imlib2_test because its dependency /usr/lib64/libImlib2.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/auth because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/stats because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/eu-unstrip because its dependency /usr/lib64/libdw.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/named-checkconf because its dependency /usr/lib64/libbind9.so.80 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/htdigest because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/eu-nm because its dependency /usr/lib64/libdw.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/openssl because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/certutil because its dependency /usr/lib64/libssl3.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/tcsd because its dependency /usr/lib64/libcrypto.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/httxt2dbm because its dependency /usr/local/lib/libpcre.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/replicator because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gpgv2 because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/nslookup because its dependency /usr/lib64/liblwres.so.80 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/lib64/libOpenIPMIcmdlang.so.0 because its dependency /usr/lib64/libOpenIPMI.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/xml2text because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/clamscan because its dependency /usr/lib64/libclamav.so.6 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/aggregator because its dependency /usr/lib/dovecot/libdovecot.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/eu-readelf because its dependency /usr/lib64/libdw.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/mkfontscale because its dependency /usr/lib64/libfontenc.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/gprof because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/openipmish because its dependency /usr/lib64/libOpenIPMIcmdlang.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/doveadm because its dependency /usr/local/lib/libz.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/nsupdate because its dependency /usr/lib64/liblwres.so.80 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ab because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pdffonts because its dependency /usr/lib64/libpoppler.so.5 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/mpg123 because its dependency /usr/lib64/libmpg123.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/addr2line because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/webalizer because its dependency /usr/lib64/libgd.so.2 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/file because its dependency /usr/lib64/libmagic.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/as because its dependency /usr/lib64/libopcodes-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/reporter-upload because its dependency /usr/lib64/libabrt_web.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/ar because its dependency /usr/lib64/libbfd-2.20.51.0.2-5.36.el6.so could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/pcretest because its dependency /usr/lib64/libpcreposix.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/reporter-kerneloops because its dependency /usr/lib64/libabrt_web.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/mencoder because its dependency /usr/lib64/libfontconfig.so.1 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/libexec/dovecot/quota-status because its dependency /usr/lib/dovecot/libdovecot-storage.so.0 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/dnssec-settime because its dependency /usr/lib64/libdns.so.81 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/bin/w3m because its dependency /usr/lib64/libssl.so.10 could not be prelinked
/usr/sbin/prelink: Could not prelink /usr/sbin/genrandom because its dependency /usr/lib64/libisc.so.83 could not be prelinked
Prelink failed with return value 134
I find it strange that this happens on all three servers of mine, 2 dedicated servers, and 1 xen vps. I have not been able to figure out what is wrong and what I can do to fix it. It happens every night if I have installed or upgraded something on the server, or if I have run ldconfig. Has anybody seen this before?
Yes, I had those emails and kindlike errors too some time ago. Since also the firewall sometimes gave problems with pt_deleted notices when upgrading things that were prelinked, I just turned prelinking off.
If you also wan to set it of, edit /etc/sysconfig/prelink and set "prelinking = no" and save the file.
Then either reboot your server or to have it effective immediately issue this command:
prelink -ua
Thank you very much, Richard. However I need to think more about it, and try to investigate more. It seems to me that there is many different opinions as to whether or not prelink is required. I don't know at all myself. So I am not sure what is best/worst, to have broken prelink (like I do), or to disable it. Hopefully there will be more replies. I would feel it safest if I was able to find and fix my prelink problem.
What is strange, I have the problem on all three servers, and it started about the same time few months ago. But I have just a week ago setup a new server, wich does not yet have this problem. So I think it must be something that happen during previous upgrades, and because I run exactly same setup on all three servers, I have the same prelink problem on them.
Well, I understand your thoughts and in that case I'm also curious to other reply's. Because what you describe here is exactly what we had on our 3 Centos 5.x servers. No problems in the beginning, but after some upgrades it started and they were also setup exactly the same.
We don't have the problem on our Centos 6 servers anymore because Centos 6 does not have prelink anymore by default.
But I'm sure interested in solutions or thoughts from others, because like you I'm technically interested in what's causing things.
[..]We don't have the problem on our Centos 6 servers anymore because Centos 6 does not have prelink anymore by default.
Are you sure? Because I have a brand new server, one week old, with CentOS 6.4 64bit (it was installed CentOS minimal by the datacenter before being delivered to me), and when I check /etc/sysconfig/prelink on that server, it has this line in it:
PRELINKING=yes
But maybe the datacenter installed and older CentOS 6.x and upgraded to newest before delivering it to me, if the default prelinking was not changed until recent CentOS 6.x versions?
Just wanted to say that on my newest server, it seems to be default that prelinking is activated. I am going to try to disable it now ...
I had this problem too with CentOS 5.x and i did disable it too (also from cron.daily folder).
If I may ask, how did you do it? Did you just delete/rename /etc/cron.daily/prelink , or did you change values inside it?
Are there benefits from (re)moving prelink from cron.daily?
Because the first line of the prelink file contains this:
. /etc/sysconfig/prelink
And in there it states "prelinking = no".
Since the next lines in the cronjob reads:
if [ "$PRELINKING" != yes ]; then
It looks like it will do nothing anymore. Even the "else" which would make a prelink.full and prelink.quick in /var/lib/misc seems not to be made anymore. I got the cronjob in place and those files on my server are dated juli last year, which is when I disabled prelink.
That's why I'm wondering which benefits it would have to (re)move the cronjob totally?
Well probably when i did that i was heavy mad about prelink and i did want to remove it definitly :)
No valid reason, actually, i did not read the content of the cron either, so, maybe (probably) is not needed to disable it.
Regards
I like that statement! Thank you both. I have now disabled prelink in all my 4 servers. Actually I have a good feeling about this now. :)
LoL... Ik had that same feeling at that time.:D
Actually I was so mad I complete forgot there was a cronjob, just found that out several days later. But since it didn't do anything anymore, I then just left it there. Good chance that if I had discovered it the same day, I also would have moved it out of angryness.:p
