Cron Job error - Help needed
lampodiiluce
I am new to Directadmin and i was trying to add a cronjob but i get this error:
"Error Creating Cron Job
Details
crontab returned non zero value: "./data/users/mydomain/crontab.conf.tmp":1: bad command errors in crontab file, can't install."
This is the command i have entered:
/usr/local/lib/php /home/mydomain/domains/mydomain.com/public_html/mcn/cron.php > /dev/null 2>&1
what can i do to fix this error?
hope you can help me.
thanx
Good to see you back on the forum. It's been a while. Will the Easy Cronjob Handler work with DirectAdmin? How/where do you install it? Where does it save the cronjobs? Is it DirectAdmin specific?
