B blog Verified User Joined Jan 28, 2011 Messages 130 Feb 15, 2013 #1 Hi Install DA Nginx and login to Direct Admin > ConfigServer Firewall&Security I have this message: Permission denied [User:admin UID:501] How I can fix issue? Thank you.
D DoubleUare Verified User Joined Jun 23, 2007 Messages 14 Feb 19, 2013 #2 Same issue here... Help! Somebody?
Greenhost Verified User Joined Jan 22, 2013 Messages 115 Feb 19, 2013 #3 Just update the DA, that solve the issue
Greenhost Verified User Joined Jan 22, 2013 Messages 115 Feb 19, 2013 #4 You should update permission, So updating DA should change that. Check your permission by following command: Code: ls -la /usr/local/directadmin/data/admin/admin.list
D DoubleUare Verified User Joined Jun 23, 2007 Messages 14 Feb 22, 2013 #5 Found my error... DAnginx 4.0 somehow triggers the CSF- and Installatron webinterface to fail, its not "admin.list".
unixguru Verified User Joined Mar 6, 2010 Messages 67 Location Four Marks, Alton, Hampshire Jun 15, 2013 #6 Just reinstall CSF after DaNGINX and you will be fine.
V vverloop Verified User Joined Mar 30, 2010 Messages 31 Jul 28, 2014 #7 Uninstall your firewall... unixguru said: Just reinstall CSF after DaNGINX and you will be fine. Click to expand... The worst solution i ever hurt. Uninstall your firewall...not good! There must be another solution!
P Petertjuh360 Verified User Joined Nov 7, 2010 Messages 327 Jul 28, 2014 #8 vverloop said: The worst solution i ever hurt. Uninstall your firewall...not good! There must be another solution! Click to expand... He says reinstall. Reinstall = first uninstall and then install it again.
BBM Verified User Joined Jun 8, 2013 Messages 402 Location Dutch Mountains Jul 28, 2014 #9 And I'm sure it doesn't hurt either... At least, that's what I've heard...
