This code is not from the attached templates (that templates will be used in future versions of DA).
No, no... I was not referring to the new custom that you attached in the previous message, this code is from current DA pre-release:
Compiled on 'CentOS 6.0 64-Bit'
Compile time: Jun 23 2013 at 01:17:14
Compiled with IPv6
By using PHP1 5.4 FPM and PHP2 5.3 FPM, Apache can not start and displays various errors in every user http.conf:
Starting httpd: AH00526: Syntax error on line 63 of /usr/local/directadmin/data/users/admin/httpd.conf:
RewriteCond: bad flag delimiters
Starting httpd: AH00526: Syntax error on line 123 of /usr/local/directadmin/data/users/admin/httpd.conf:
RewriteRule: bad flag delimiters
I solved by editing the files:
/usr/local/directadmin/data/templates/virtual_host2.conf
/usr/local/directadmin/data/templates/virtual_host2_secure.conf
/usr/local/directadmin/data/templates/virtual_host2_secure_sub.conf
/usr/local/directadmin/data/templates/virtual_host2_sub.conf
as I have specified in the previous message.
Simply warned to help, although I know that soon will change for the new templates you've created.
P.D. Ups! Sorry we have appropriated this thread with other unrelated problems, should a moderator separate unrelated posts (14,15,16,17,18,19,20,21,22,24,25) and move them to a new thread for PHP-FPM in CB2 subforum.
