After upgrade Directadmin Version 1.431 i get libmysqlclient.so.18: no version inform
Marwen
germany
Hi John.
I have upgrade two Debian 6 (64bit) boxes today with DA 1.431.
After the upgrade i get.
/usr/local/directadmin/dataskq: /usr/local/mysql/lib/libmysqlclient.so.18: no version information available (required by /usr/local/directadmin/dataskq)
or with custombuid
root@dns02:/usr/local/directadmin/custombuild# ./build versions
/usr/local/directadmin/directadmin: /usr/local/mysql/lib/libmysqlclient.so.18: no version information available (required by /usr/local/directadmin/directadmin)
Latest version of DirectAdmin: 1.43.0
Installed version of DirectAdmin: 1.43.1
thanks for help
I have allready try it. But it dosen´t work.
root@dns02:/usr/lib64# ls -l /usr/local/mysql/lib | grep libmysqlclient
-rw-r--r-- 1 mysql mysql 14743256 May 16 18:28 libmysqlclient.a
lrwxrwxrwx 1 mysql mysql 20 Jun 24 15:28 libmysqlclient.so -> libmysqlclient.so.18
-rwxr-xr-x 1 mysql mysql 6053926 Oct 26 2011 libmysqlclient.so.16
lrwxrwxrwx 1 mysql mysql 24 Jun 24 15:28 libmysqlclient.so.18 -> libmysqlclient.so.18.0.0
-rwxr-xr-x 1 mysql mysql 6891649 May 16 18:28 libmysqlclient.so.18.0.0
lrwxrwxrwx 1 mysql mysql 16 Jun 24 15:28 libmysqlclient_r.a -> libmysqlclient.a
lrwxrwxrwx 1 mysql mysql 17 Jun 24 15:28 libmysqlclient_r.so -> libmysqlclient.so
lrwxrwxrwx 1 mysql mysql 17 Jun 24 15:28 libmysqlclient_r.so.18 -> libmysqlclient.so
lrwxrwxrwx 1 mysql mysql 17 Jun 24 15:28 libmysqlclient_r.so.18.0.0 -> libmysqlclient.so
root@dns02:/usr/lib64# /etc/init.d/directadmin restart
Stopping DirectAdmin: [ OK ]
Starting DirectAdmin: /usr/local/directadmin/directadmin: /usr/local/mysql/lib/libmysqlclient.so.18: no version information available (required by /usr/local/directadmin/directadmin)
[ OK ]
When i replace the OLD DA Binery it works without error message.
same issue here
debian6 x86
root@server:~# service directadmin restart
Stopping DirectAdmin: [ FAILED ]
Starting DirectAdmin: /usr/local/directadmin/directadmin: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
[ FAILED ]
root@server:~# ls -l /usr/local/mysql/lib | grep libmysqlclient
-rw-r--r-- 1 root mysql 10381390 Jan 20 2011 libmysqlclient.a
lrwxrwxrwx 1 root mysql 16 Nov 2 2011 libmysqlclient_r.a -> libmysqlclient.a
lrwxrwxrwx 1 root mysql 17 Nov 2 2011 libmysqlclient_r.so -> libmysqlclient.so
lrwxrwxrwx 1 root mysql 20 Nov 2 2011 libmysqlclient.so -> libmysqlclient.so.16
lrwxrwxrwx 1 root mysql 24 Jun 24 19:53 libmysqlclient.so.16 -> libmysqlclient.so.16.0.0
-rwxr-xr-x 1 root mysql 6053926 Jan 20 2011 libmysqlclient.so.16.0.0
lrwxrwxrwx 1 root mysql 20 Jun 24 19:54 libmysqlclient.so.18 -> libmysqlclient.so.16
root@server:~#
root@server:~# cd /usr/lib
root@server:/usr/lib# ln -s libmysqlclient.so.16 libmysqlclient.so.18
root@server:/usr/lib# service directadmin restart
Starting DirectAdmin: /usr/local/directadmin/directadmin: /usr/lib/libmysqlclient.so.18: version `libmysqlclient_18' not found (required by /usr/local/directadmin/directadmin)
[ FAILED ]
Help please.
Also total 6 hours 30min - support DA still not answer.
no comments...
After some next hours i'm found solution:
DireactAdmin not look into /usr/local/mysq/lib/ on Debian6, where DA making update with symbolic link libmysqlclient.so.18
and looking only in /usr/lib/ where symbolic link libmysqlclient.so.18 not available
/usr/lib/ (or lib64) also can contain another version of libmysqlclient.so.16 and symbolic link to the same directory will not help
so, lets make right fix:
root@server: cd /usr/lib
root@server:/usr/lib# ln -s /usr/local/mysq/lib/libmysqlclient.so.16 libmysqlclient.so.18
Starting DirectAdmin: /usr/local/directadmin/directadmin: /usr/lib/libmysqlclient.so.18: no version information available (required by /usr/local/directadmin/directadmin)
[ OK ]
Error still available, but DirectAdmin working fine.
If this solution not help you, do try make symbolic link for libmysqlclient.so.18 from /usr/lib (or from /usr/local/lib) to /usr/local/mysql/lib/libmysqlclient.so.16 or /usr/mysql/lib/libmysqlclient.so.16
For 64-bit debian lib will be lib64 i think.
Thanks for the reports. This issue turns out to have been just on that build system, and was resolved quickly, but some Debian 6 32-bit servers that updated in that window may be affected.
It's been sorted out in the packages, but for anyone affected, grab new binaries with this guide:
http://help.directadmin.com/item.php?id=29
Our apologies for anyone affected by the issue.
i follow this steps:
cd /usr/local/directadmin
wget --no-check-certificate -O update.tar.gz 'https://www.directadmin.com/cgi-bin/daupdate?redirect=ok&uid=123&lid=1234'
tar xvzf update.tar.gz
./directadmin p
cd scripts
./update.sh
but i get the same error:
root@dns01:/usr/local/directadmin/scripts# ./update.sh
Stopping DA-PopB4Smtp:
Starting DA-PopB4Smtp:
root@dns01:/usr/local/directadmin/scripts# /etc/init.d/directadmin restart
[ OK ]
autoupdate DA was not a good choice in custombuild. :(
All my boxes spam me up with cron daemon messages. :(
only recover the old directadmin file from yesterday fix the error and the messages
DirectAdmin: the fix you proposed does not work:
root@whirlpool:/usr/local/directadmin# ./directadmin p
./directadmin: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
root@whirlpool:/usr/local/directadmin# cd scripts/
root@whirlpool:/usr/local/directadmin/scripts# ./update.sh
root@whirlpool:/usr/local/directadmin/scripts# /etc/init.d/directadmin restart
[ FAILED ]
Please fix this now, i have customers complaining! Atleast tell me how I can rollback the update, all was working fine yesterday. I run Debian 6 x64 too.
Same error on my machine after automatic upgrade DA.
Error came around 6 am today
root@srv:/usr/local/directadmin# /etc/init.d/directadmin restart
[ FAILED ]
I have Debian 6.0 64 bits
Please help !!
I've got a fix too:
- remove any symlinks you just created in /usr/local/mysql/lib
- download latest update as described here: http://help.directadmin.com/item.php?id=29
- make sure you run the ./update.sh script
- create symlink: ln -s /usr/local/mysql/lib/libmysqlclient.so.18 /usr/lib/libmysqlclient.so.18
- try to start directadmin: service directadmin start
for me this results in:
[ OK ]
Not ideal but it seems to work. DirectAdmin: please create a proper fix for this issue. Also, I don't know if I screwed up any of my libmysqlclient.so files while trying the numerous non working fixes... is there any way to 'rebuild' those files/symlinks?
I've got a fix too:
[ OK ]
That only gets me:
# /etc/init.d/directadmin start
[ FAILED ]
Getting the /usr/local/directadmin/directadmin binary from tonight's backup fixed it for us, error free!
Confirmed, everything is working again.
(I also removed the binaries I posted earlier, so the links above are now broken)
