How to stop SSH login cracking attack?
mr-cracker
Hello all,
I use CSF firewall, and the Deny IP List is full of
219.129.21.4 # lfd: (sshd) Failed SSH login from 219.129.21.4 (CN/China/-): 5 in the last 3600 secs - Fri May 24 10:57:03 2013
119.36.186.44 # lfd: (sshd) Failed SSH login from 119.36.186.44 (CN/China/119.36.arpa.hb.cnc.cn): 5 in the last 3600 secs - Fri May 24 20:49:29 2013
220.178.18.67 # lfd: (sshd) Failed SSH login from 220.178.18.67 (CN/China/-): 5 in the last 3600 secs - Sat May 25 11:04:03 2013
193.111.141.244 # lfd: (PERMBLOCK) 193.111.141.244 has had more than 4 temp blocks in the last 86400 secs - Sat May 25 13:24:45 2013
124.160.194.27 # lfd: (sshd) Failed SSH login from 124.160.194.27 (CN/China/-): 5 in the last 3600 secs - Sat May 25 19:16:18 2013
My password is very hard to guess, but this has been going for months now, so I want to stop it once and for all. I guess changing the SSH port will help. But I don't know how to do it?
Any ideas guys?
  1. Go to your SSH console
  2. Type: nano /etc/ssh/sshd_config
  3. Change #port 22 to port xxx
  4. Save with CTRL + x and then y
  5. Type: service sshd restart
  6. SSH port changed
stop attack? shut down your server, this the best solution,
they is no sucessful solution for that
but
1. change ssh port
2. allow only access from your ip
3. don't use password auth, use pubkey
I would suggest only to use option 1 and 2 if you are on a dynamic ip. Because when it changes, you block yourselve out of your own server without an option to fix it, except via your provider/datacenter.
Normally option 1 and 2 are already enough, and almost no attacks are seen anymore.
