I have been following the guide here (on my Debian machine
http://help.directadmin.com/item.php?id=380
I have got the buttons to show and some IP info is added to iptables once it is pressed but i also get some errors (including when restarting iptables).
Does anyone have clean guide for Debian or are willing to help out, maybe we can set up a guide for Debian afterwards?
This is the error after pressing "add to block list" created by the guide in the link.
Restarting iptables ...
libkmod: ERROR ../libkmod/libkmod.c:505 kmod_lookup_alias_from_builtin_file: could not open builtin file '/lib/modules/2.6.32-042stab076.8/modules.builtin.bin' FATAL: Module ip_tables not found. libkmod: ERROR ../libkmod/libkmod.c:505 kmod_lookup_alias_from_builtin_file: could not open builtin file '/lib/modules/2.6.32-042stab076.8/modules.builtin.bin' FATAL: Module iptable_filter not found. libkmod: ERROR ../libkmod/libkmod.c:505 kmod_lookup_alias_from_builtin_file: could not open builtin file '/lib/modules/2.6.32-042stab076.8/modules.builtin.bin' FATAL: Module ip_conntrack not found. libkmod: ERROR ../libkmod/libkmod.c:505 kmod_lookup_alias_from_builtin_file: could not open builtin file '/lib/modules/2.6.32-042stab076.8/modules.builtin.bin' FATAL: Module ip_conntrack_ftp not found. /etc/init.d/iptables: line 93: /proc/sys/net/ipv4/tcp_timestamps: Permission denied /etc/init.d/iptables: line 105: /proc/sys/net/ipv4/ip_dynaddr: Permission denied /etc/init.d/iptables: line 112: /proc/sys/net/ipv4/ip_local_port_range: Permission denied /etc/init.d/iptables: line 115: /proc/sys/net/ipv4/tcp_fin_timeout: Permission denied /etc/init.d/iptables: line 116: /proc/sys/net/ipv4/tcp_keepalive_time: Permission denied /etc/init.d/iptables: line 117: /proc/sys/net/ipv4/tcp_window_scaling: Permission denied /etc/init.d/iptables: line 118: /proc/sys/net/ipv4/tcp_sack: Permission denied /etc/init.d/iptables: line 119: /proc/sys/net/ipv4/tcp_max_syn_backlog: Permission denied iptables: No chain/target/match by that name. iptables: No chain/target/match by that name.
Thank you
Thank you
