*** An error has occurred while trying to update the software ***
21secolo
Italy - Rome
Hi, I have recived this error message:
This is an automated message notifying you that an error has occurred while trying to update the software.
The generated error message is as follows:
Error restoring file /usr/local/directadmin/update.tar.gz :
gzip: stdin: unexpected end of file
/bin/tar: Child returned status 1
/bin/tar: Error exit delayed from previous errors
: tar returned error code 512<br>
<br>
<br>
Try updating manually: http://help.directadmin.com/item.php?id=29<br>
...but when I try to update manually, when I download the .gz update file, I see the "update.tar.gz" file is 0 Kb in /usr/local/directadmin directory and the update is not applied but obviously no other errors appear.
Can you help me?
now i see that work the manually update but the version number do not change like this:
DirectAdmin Values
Compiled for Debian 5.0
Compile Date Sep 26 2013, 23:10:13
Server Version 1.44.0
Current Available Version 1.441000
Last Updated Fri Sep 27 07:11:28 2013
And if I see the "update.tar.gz" file properties I can look this date: 27/09/2013
I think that isn't the last update file downloaded but I'm sure this file is the file downloaded because first I delete the old "update.tar.gz... why???
