update named
blog
Hi
I have Named 9.3.6 I will update to new version how do it?
Centos 5
run
yum clean all
yum update bind
but isn't updated?
Thank you.
If you do
yum check-update
is it presenting a newer version of bind?
run yum check-update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.atlanticmetro.net
* extras: mirror.thelinuxfix.com
* updates: mirror.trouble-free.net
Excluding Packages in global exclude list
Finished
yum update bind\*
yum update bind\*
Finished
Setting up Update Process
No Packages marked for Update
@Ben29: That's no use. If yum check-update will not show any version of bind, neither will your command.
@Blog: Check your /etc/yum.conf maybe bind* is excluded in there. Only bind-chroot* should be excluded.
If bind is excluded, remove bind (leave bind-chroot* in place) and save the file.
After that run yum update bind again.
I have this line in my yum.conf
exclude=apache* httpd* mod_* mysql* MySQL* da_* *ftp* exim* sendmail* php* bind-chroot*
change to?
exclude=apache* httpd* mod_* mysql* MySQL* da_* *ftp* exim* sendmail* php* bind*
No dont do that. Centos does not use the newest versions of software. Why do you think it needs to be upgraded?
usually upgrade software for security and better efficiency it isn't necessary?
Centos patches older versions of software for security holes when there are some. They like to stay on older versions because they feel it is more stable. You could install a newer version of bind but you will need a repository that supports that newer version or a rpm/srpm that you install manually.
... and of course you may need a complete library structure to support the new version, or a statically-compiled program.
