possible bug with ipv6 ?
dmacleo
as soon as an ipv6 ip assigned to user apache fails with
Starting httpd: [Sat Jan 11 19:13:44.691654 2014] [core:error] [pid 23587] (EAI 2)Name or service not known: AH00547: Could not resolve host name IP REMOVED:80[ IPV6 IP REMOVED] -- ignoring!
doing ./build rewrite_confs does not help
sure looks like it, this server was built on 12-27 so should have the corrected CB.
I cannot remember how to check and update CB itself, can you tell me please?
Just run "./build update" should be enough to get the newest versions of CB, and to check what version you are running, just run "./build", at the top it should say "Version: 2.0.0-RC6" if you have the newest version.
I am pretty sure I entered ipv6 info correctly too
my block is
2604:4300:a:b::1/64
so for the one domain I am using to test I assigned
2604:4300:000a:000b:0000:0000:0000:0000
as all ipv6 calculators said that was start address.
however running
grep `hostname` /etc/hosts | awk '{print $1}'
only gives the ipv4 ip so I am not sure if I got the ipv6 ip correct.
thanks I am RC6 so maybe there is another issue
ok will do a ./build update
thanks guys I appreciate the advice here
did ./build update and still have issue.
am I using correct ip format?
Your /etc/hosts should show both IPs, so if you have only the V4, add the V6
2604:4300:a:b:0:0:0:1
But that won't solve your problem since it seems to be related to additional IPs.
Your IP (2604:4300:000a:000b:0000:0000:0000:0000) looks wrong. Add this one to DA
2604:4300:a:b:0:0:2:1 mask /64
and try adding it to a customer
same error
will post full thing:
Starting httpd: [Sat Jan 11 20:01:16.499148 2014] [core:error] [pid 12073] (EAI 2)Name or service not known: AH00547: Could not resolve host name 173.208.129.114:80[2604:4300:a:b:0:0:2:1] -- ignoring!
is there something I should have done server level (centos 6.6) to make sure these were actually available? the datacenter says they added but...
yeah I bet thats it
ifcfg-eth0 doesn't have the info in it
yeah I got a ton of reading to do first to see how to add these to server. I misunderstood datacenter and thought they had actually added them.
