B blog Verified User Joined Jan 28, 2011 Messages 128 Feb 3, 2014 #1 Hi To All login to reseller account > IP Management > here is only one it is main server ip with Status "server" where is reseller ip? in admin level I have ip Status "shared" and it is assign to reseller what is issue?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,167 Location www.poralix.com Feb 4, 2014 #2 Hello, Just check and make sure you've got assigned to the reseller IPs here in the file: /usr/local/directadmin/data/users/<RESELLER_NAME>/ip.list if you don't, then add them manually. That's it.
B blog Verified User Joined Jan 28, 2011 Messages 128 Feb 5, 2014 #3 add manually but isn't listed in reseller IP Management
zEitEr Super Moderator Joined Apr 11, 2005 Messages 16,167 Location www.poralix.com Feb 5, 2014 #4 Make sure you've got an empty line in the file after an IP.
B blog Verified User Joined Jan 28, 2011 Messages 128 Feb 5, 2014 #5 zEitEr said: Make sure you've got an empty line in the file after an IP. Click to expand... many thanks it is fixed
