FTP from a server IP to server IP
LawsHosting
London UK
Ok, this is confusing, when people upgrade their WordPress via its internal FTP routine (may happen with more CMS's though) to AN_IP_ON_SERVER<>AN_IP_ON_SERVER, although the updates are fine, I get this in my kern.log:
kernel: nf_ct_ftp: dropping packetIN= OUT=lo SRC=AN_IP_ON_SERVER DST=AN_IP_ON_SERVER LEN=104 TOS=0x00 PREC=0x00 TTL=64 ID=703 DF PROTO=TCP SPT=21 DPT=51892 SEQ=3977930889 ACK=3985423869 WINDOW=747 RES=0x00 ACK PSH URGP=0 OPT (0101080A1952DA671952CDDA) UID=107 GID=110
Google, although a mine for information, didn't really turn up with anything.
Any insights will be grateful.
Do you have a set list of passive ports opened through your firewall? It is in the guide on csf.
ftp is tcp only but I definately wouldnt open that many ports... you should be fine by opening only 1000 ports or so and then setting those ports to PassivePorts in proftpd.conf
