- Feb 27, 2003
DirectAdmin 1.45.0 Release Candidate 1 is now available for testing.
1.45.0 versions entry
To install this version, use the pre-release guide:
http://help.directadmin.com/item.php?id=408
Note: This is going to be an accelerated testing schedule due to a possible security issue.
New features:
Ability to bypass domain checks for restore with Multi Server Setup
Ajax checking on domain, Username, password forms (needs to be turned on: ajax=1)
Alternate email for high-volume messages, namely the brute force monitor (prevents inbox clutter)
Ability to add IPv6 IPs into your SPF records without needing templates changes.
domain exceptions list for subdomain_owners_check.
Custom per-User list of skipped paths in backups
send notice to email account upon hittng send limit (friendly html email)
Bugfixes:
Important security fix for memory issue. Will disclose more info once tested and released.
dataksq uses 100% cpu with too many email deliveries
Disbale SSL re-negotiation to satisfy PCI compliance
rewrite inherit template changes for CB use_hostname_for_alias option
We encourage anyone who is willing to test this release to do so, and report back any found issues, or even if no issues are found.
The version of the binaries will still show 1.44.3, but you can tell you have the new version by running "./directadmin o" and checking for the March 1st compile date.
New features:
Bugfixes:
