IT_Architect
- Feb 27, 2006
"The server you are connected to is using a security certificate that cannot be veri"
Outlook Send error:
"The server you are connected to is using a security certificate that cannot be verified"
"The target principal name is incorrect"
"Do you want to continue to use this server?"
If I answer OK, it will use it a while, probably until I reboot, or maybe if I shut down and restart Outlook.
It has a regular cert, and it works perfectly on POP3 and web mail.
Outlook Send error:
