inferencia
Are we fast, or what?
I did found another visual bug, this time from Android phone
Regards
Also, at user level, should be nice the GB thing
undefined10965.3MB010965.3
UNLIMITED
Bandwidth
undefined3415.1MB03415.1
At the right column
Regards
process monitor auto reload only cycles once?
in the default it will reload every 'X' seconds
Remember to upload the file AS IS (it's a tar.gz file that you download from cyberneticos.com cliente area). DO NOT gunzip or untar the tar ball or even open it from your PC.
Just upload it exactly as you downloaded it, as with any other skin.
Thanks.
CyberAdmin encrypts his files to prevent abuse of the skin (stealing the codes and removing the licensing system). To read this encryption, you need IonCube.
I don't know why it is a big problem to upgrade/rebuild? You should have PHP 5.3+ by now and IonCube supported.
Hi bluenet and AndyII,
What version of PHP and Ioncube loader are installed on your servers?
We are going to seek a solution to your problem, but we need to know the specific versions for PHP and Ioncube loader.
Sorry for the inconvenience!
skin should work with ... any version of directadmin
Using Centos and Directadmin 5.5 says:
CentOS 5: March 2017 -> March 2018
