# This is the main Apache HTTP server configuration file. It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.2> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.2/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
ServerRoot "/etc/httpd"
Listen 80
#LoadModule dummy_module /usr/lib/apache/mod_dummy.so
Include /etc/httpd/conf/extra/httpd-phpmodules.conf
User apache
Group apache
ServerAdmin admin@localhost
DocumentRoot "/var/www/html"
# Options and AllowOverrides
Include conf/extra/httpd-directories.conf
<IfModule dir_module>
DirectoryIndex index.html index.htm index.shtml index.php index.php5 index.p hp4 index.php3 index.phtml index.cgi
</IfModule>
<FilesMatch "^\.ht">
Order allow,deny
Deny from all
Satisfy All
</FilesMatch>
ErrorLog /var/log/httpd/error_log
LogLevel warn
<IfModule log_config_module>
#replace %b with %O for more accurate logging
<IfModule mod_logio.c>
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" c ombined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%O %I" bytes
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
</IfModule>
CustomLog /var/log/httpd/access_log common
</IfModule>
<IfModule alias_module>
# Include some DirectAdmin alias
Include conf/extra/httpd-alias.conf
</IfModule>
DefaultType text/plain
<IfModule mime_module>
TypesConfig conf/mime.types
AddType application/x-gzip .tgz
AddEncoding x-compress .Z
AddEncoding x-gzip .gz .tgz
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddHandler cgi-script .cgi
AddHandler type-map var
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
AddType video/x-ms-asf .avi
AddType video/mpeg .mpg
AddType video/mpeg .mpeg
AddType video/quicktime .mov
AddType video/x-ms-wmv .wmv
</IfModule>
#EnableMMAP off
#EnableSendfile off
# For user configurations not maintained by DirectAdmin. Empty by default.
Include conf/extra/httpd-includes.conf
# Do not change anything in included files, because they are rewritten by Direct Admin #
# This is needed for PHP
Include conf/extra/httpd-php-handlers.conf
# Server-pool management (MPM specific)
Include conf/extra/httpd-mpm.conf
# Multi-language error messages
Include conf/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
Include conf/extra/httpd-autoindex.conf
# Language settings
Include conf/extra/httpd-languages.conf
# User home directories
#Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
Include conf/extra/httpd-info.conf
# Virtual hosts
Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
Include conf/extra/httpd-dav.conf
# Various default settings
Include conf/extra/httpd-default.conf
# Secure (SSL/TLS) connections
Include conf/extra/httpd-ssl.conf
# Deflate module settings
Include conf/extra/httpd-deflate.conf
# All the DirectAdmin vhosts
Include conf/extra/directadmin-vhosts.conf
# All suPHP directives
Include conf/extra/httpd-suphp.conf
# End of included files that are rewritten by DirectAdmin #
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
