Directadmin 1.45.4 has been released
DirectAdmin Support
Administrator
Staff member
DirectAdmin 1.45.3 and 1.45.4 have been released.
1.45.3 versions entry
1.45.4 versions entry
This release has many bug-fixes as well as many new features.
1.45.4 was released shortly after 1.45.3 after the discovery of a pipe bug in the dataskq.
New Features:
Bug Fixes:
We also recommend setting
ajax=1
into your directadmin.conf. We may enable this as a default option for a future release.
Ajax adds many features, such as auto-fills, live form checking with friendly messages, etc..
Hi
I view this http://www.directadmin.com/features.php?id=1597
and saw that when you do a skin update we need to require a ctrl-F5 for stylesheet css reload
if you will add version to css files we not need to do this
like this:
<link type="text/css" rel="stylesheet" href="file.css?v={directadminversion}" />
<link type="text/css" rel="stylesheet" href="file.css?v=1.45.4" />
so every time you update directadmin the css change to the version auto.
sorry for my bad English.
Hi.
If i add an new IP in DA under IP Management i get an Error
"sh: command not found"
the added Ip was listed in the IP Management but not on the system.
Testet on 2 systems.
Compiled on CentOS 6.0 64-Bit
Compile Date Jul 1 2014, 01:50:48
Server Version 1.45.4
Current Available Version 1.454000
Hmm, no other reports as of yet.
Try in ssh, to see what it does:
./addip.sh 1.2.3.4 255.255.255.0 eth0
adjust the values as needed.
I just added an IP, version 1.45.4
no troubles, the IP was added without any error
Hi John.
./addip 1.2.3.4 255.255.255.0 eth0 ) without .sh works and add a interface.
On another system it works also without problems. :( very crasy.
i will look forward what is worng with the both systems.
thanks for help.
Hi John.
i find a mad entry in the first line of directadmin.conf
ADDIP=/USR/LOCAL/Directadmin/scripts/addip
i can t remember that i set this entry.
Have you an idee how it is possible that i have this line in the config file ? (prerelease error ? or something else ?)
Thanks Mario
I have the same(well except the caps part)
addip=/usr/local/directadmin/scripts/addip
Yes that is correct
but my entrys on the 2 systems was
i have change it now to this
and it works.
my question is only why i have this line ADDIP=/USR/LOCAL/Directadmin/scripts/addip and not this addip=/usr/local/directadmin/scripts/addip :)
so it was he Caps that crippled it.
seems a mystery why you had caps on part of that path, :confused:
could this be an OS specific case? like the package was different
mine was done
Regarding the new exim.conf and acl checks at http://www.directadmin.com/features.php?id=1605 - does exim.conf version 2.1.2 support deny of ymlf-pc HELOs? Or is it needed to upgrade to exim.conf 4.2.2 to have that? I have looked in all the diff files, but I can't find the word "ymlf", so I am confused where the rule that block this is located? I really would like this ymlf-pc HELOs blocked.
Currently I am about to upgrade, and I am for now going to patch from exim.conf 2.1.1 to exim.conf 2.1.2
