DirectAdmin ZFS wrappers [user quota]
roman_m
Ukraine, Kiev
HOWTO: DirectAdmin ZFS user quota wrappers
Since DA has no native ZFS supoprt and no solitions proposed in forum, I made custom wrappers.
To use it, you have to create bin folder in /usr/local/directadmin and put two attached scripts from archive (repquota, edquota) into it, then chown it both to root:wheel and made it executable. Wrappers written in perl, so you must install perl from pkg repository.
Also, you need to set $volume variable in both scripts to point to your /home filesystem (t0/home in my case) and some variables in directadmin.conf to point DA to use this wrappers:
edquota=/usr/local/directadmin/bin/edquota
repquota=/usr/local/directadmin/bin/repquota
You can use attached fix_user_quotas.pl to synchronize actual DA user quota settings with your new filesystem.
And ... Enjoy sophisticated DirectAdmin on ZFS :)
Currently running one box on ZFS with FreeBSD 9.3-RELEASE, works exactly the same as UFS DA installation, but with SSD L2ARC cache that's really like a lightspeed!
  • zfs_wrappers.zip
Good news!
I think, they could use my wrappers to rewrite and compile internal code into DA binary.
DA with native ZFS support - that was a really cool thing!
Wishing all the best to DA Staff.
As far as John told me they already had implemented quota check with ZFS so i suppose they are in an advanced status.
Regards
I don't think it's true. repquota does not work, the numbers are all wrong in the CP and emails about overage are never sent.
But thanks to @roman_m, this can all be fixed!!! MANY THANKS!!!
HOW-TO (as root)
Install scripts
# cd /usr/local/directadmin/
# mkdir /usr/local/directadmin/bin
# cd /usr/local/directadmin/bin
# fetch http://forum.directadmin.com/attachment.php?attachmentid=1881&d=1406381242
# unzip zfs_wrappers.zip
# chown :wheel /usr/local/directadmin/bin/repquota
# chown :wheel /usr/local/directadmin/bin/edquota
# chmod +x /usr/local/directadmin/bin/repquota
# chmod +x /usr/local/directadmin/bin/edquota
# echo "edquota=/usr/local/directadmin/bin/edquota" >> /usr/local/directadmin/conf/directadmin.conf
# echo "repquota=/usr/local/directadmin/bin/repquota" >> /usr/local/directadmin/conf/directadmin.conf
Update and fix scripts
# nano /usr/local/directadmin/bin/edquota
Replace the name of your ZFS volume holding your users' files in the $volume variable
Replace $slice with $volume in the zfs command, line 14
# nano /usr/local/directadmin/bin/repquota
Enforce quotas and check
# chmod +x fix_quotas.pl
# ./fix_quotas.pl
# /usr/local/directadmin/bin/repquota `/usr/local/directadmin/directadmin c | grep quota_partition= | cut -d= -f2`
After that you'll need to update the reports for all of your users and you might be in for a few surprises...
echo "action=tally&value=all" >> /usr/local/directadmin/data/task.queue
You also need to fix line 9 in `edquota` script, replacing line
my $quota = $AR[1];
with
my $quota = $ARGV[1];
It's my typo, sorry.
Here is new (fixed) version
Fixed version of wrappers (no need to modify scripts excluding seting of $volume variable).
Also includes `quota` command, not used by DirectAdmin, but very useful as system-wide `quota` command wrapper.
It produces same output as standart *nix `quota` binary, just put it into /usr/local/directadmin/bin then
chown :wheel /usr/local/directadmin/bin/quota
chmod 711 /usr/local/directadmin/bin/quota
cp /usr/bin/quota /usr/bin/quota.backup
ln -s /usr/local/directadmin/bin/quota /usr/bin/quota
test:
#quota root
Disk quotas (kilobytes) for user root (uid 0): none
#quota diradmin
Disk quotas (kilobytes) for user diradmin (uid 1001):
Filesystem usage quota limit
/home 0 300 300
View attachment zfs_wrappers.zip
Disk usage not working
Thanks for this great contribution.
Al the scripts are working fine, however the disk usage reporting in Directadmin is not working.
It show's only the database size, and not the actual size of the website.
I already tried, to re-run the tally several times.
Is there anything else that i'm missing?
Best regards,
Ronnie
Hi Roman,
Can these steps be used with openZFS + Centos 8 to get 2nd-level user quotas?
