New Skin - DA-Free
Seems good , test it now
Thanks for sharing
EDIT: Works good, but it to white, my eyes hurts :)
I forgot to remove text shadowing that I was testing and that did make my eyes hurt a bit. It's fixed now.
The design is mostly done in css and the only images used are the logo, arrow, usage bar, favicon and the 4 filemanager icons.
The older browsers won't display the gradients and rounded corners but it will work as it should.
It's free, Its' my birthday ... and I gave you a present for it :)
Enjoy
nice and simple :)
Ill grab a copy:cool:
I will ask one thing, will you keep it updated if/when DA updates?
but I know some will ask for larger and more bold fonts as they tend to blend in
contrast is always a good thing with any type theme
I wanted to keep it simple, clean and fast.
As long as I use DA it will be updated, and I don't plan going back to cp.
I did have all the text in bold but then changed my mind.
If I create one with changeable colors it will be with icons and it won't be free but it will be very affordable.
Simplicity, combined with flexibility, is nice.
How about with:
changeable colors
changeable fonts
optional icons
All to make it easier to match current website look and feel for resellers?
Would you consider this as a low-priced option?
Changeable colors, fonts and optional icons would require some php and java I guess (not my strong point).
At the moment, I don't have enough free time for that project but it's a possibility.
were my thoughts as well :)
How about with:
changeable colors
changeable fonts
optional icons
plus I'd like a stab at it :)
I'm nor a site programmer, but I believe you could add changeable colors and fonts with variables which resellers or even users could modify from a plugin-style page, and that optional icons could work with conditional code which would only try to display an icon if it exists.
However, as I write above, I don't code websies or skins, so it may be a lot more complex than that.
thanks dugalex
its very beautiful.
if you can , please add icon for links ^_^
that is one thing I want to give a try at, just time is so short and so many projects, on top of that getting sick wasnt helping :(
Error Installing Skin
The skin package did not install properly. Either there were files missing, or their permissions were incorrectly set
same trouble here :(
I see is packaged differently than the 1st version which installed without error, so I repacked it same as the 1st version but showing this error
was I to delete the 1st release? and install, or just update?
You don't have to delete the 1st one. It should just install as a new skin if you name it differently. I think I packaged it wrongly. I forgot to test the file.
I'll check it out and let you know.
