System Integrity checking
groomy
AUGNY (France)
Hi, i use centos and DA. I have custombuild 2 and i use the plugins.
I have this message after a upgrade in the plugin.
The following list of files have FAILED the md5sum comparison test. This means that the file has been changed in some way. This could be a result of an OS update or application upgrade. If the change is unexpected it should be investigated:
/usr/bin/newaliases: FAILED
/usr/sbin/exigrep: FAILED
/usr/sbin/exim: FAILED
/usr/sbin/exim_dbmbuild: FAILED
/usr/sbin/exim_dbmbuild.O: FAILED
/usr/sbin/eximstats: FAILED
/usr/sbin/exipick: FAILED
/usr/sbin/exiqgrep: FAILED
/usr/sbin/sendmail: FAILED
/usr/local/bin/curl: FAILED
/usr/local/bin/curl-config: FAILED
What is this message, because i not have probleme in DA and the website ? Thanks :(
I've never seen the message and I don't use the plugin, so this is a very simplistic answer.
Generally this sort of message means that something checked the md5sum for these files, and the return didn't match what the checking program thought it should be.
May be totally innocent.
The warnings come from LFD (a part of CSF/LFD installation), and if you previously upgraded software on your server either with rpm/yum or custombuild that's OK to get such a notification. If you did not upgrade anything either manually or with cron, and did not ask anybody to do the upgrade then you might need to worry.
No, with the upgrade the binaries' md5sum changes, that's why LFD sent a notice. No need to worry if it was you who have performed the upgrade.
